So I took in my 2008 T2 to Libertyville VW here in Illinois for a simple tiptronic switch replacement under warranty. While there I also had the bodyshop do some minor paint repair. When my wife picks up the car, she notices that someone was snooping around in the spare wheel compartment and my RNS-510 is not properly communicating with the car. The 510 does not turn on or off with the car, there is no menu for radio, navigation, or compass in the mfi, it says fault in the digital display for the compass, and the lights do not light up with the rest of the instruments in the car. So obviously the vehicle does not recognize the 510. After vaging the car the following fault codes were displayed(see below). None of the faults were there before taking the car to the dealer except for the rear view camera since I haven't purchased the "B" camera ecu yet, and the satelite radio since I haven't had time to run the new wire.
When I take the car back in to have them fix the issue, they say they can not fix the problem because the 510 is not orginal equipment and tech support has no idea what is wrong or how to fix it. Tech support adamently says that the 510 needs to be coded and is not simply plug and play. The service writer even asked if the 510 is aftermarket because the parts guy can't find it in etka. I simply told him there is a VW part number on the unit itself and to check his lot for any 2010 Tregs with navi and to his surprise he will see the same thing.
So what is the problem? I already put in a call to Ross-Tech and someone is reviewing my codes but I thought I would post to see if anyone here has any experience with a similar issue. I'm assuming for some reason either the VW tech or the body shop dissconnected the battery and reconnected it and the CAN system freaked out. Any help would be greatly appreciated.
Erik
VCDS Version: Release 10.6.0
Data version: 20100630
Friday,16,July,2010,17:21:48:06853
Chassis Type: 7L - VW Touareg
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGMB77L98D025693 Mileage: 53120km/33007miles
Address 17: Instruments Labels: 7L6-920-xxx-17-7L6.lbl
Part No SW: 7L6 920 990 HW: 7L6 920 990
Component: J285 KOMBI-INST. 7520
Revision: KHH06V02
Coding: 0005201
Shop #: WSC 40212 444 84272
VCID: F6E8754FF8AF
2 Faults Found:
01304 - Radio
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:22
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:22
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No SW: 6N0 909 901 HW: 7L6 920 990
Component: J533 GW-K-CAN TP20 7520
Coding: 7FE2FFD94B046002
VCID: F0E443579ACB
4 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:10
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:22
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:12
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No SW: 7L6 919 044 Q HW: 7L6 919 044 Q
Component: J702 Dachdisplay 0400
Revision: --30004S Serial number: 00000000034305
Shop #: WSC 03999 444 54535
VCID: 458A428375C9
1 Fault Found:
00464 - Control Module with Display for Radio and Navigation (J503)
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:13
Erik
Revision: KHH06V02
Coding: 0005201
VCID: F6E8754FF8AF
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:22
VCID: F0E443579ACB
4 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:10
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:12
VCID: 458A428375C9
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 112
Mileage: 53002 km
Time Indication: 0
Date: 2010.07.16
Time: 10:56:13
