1 - 9 of 9 Posts
Hi there, help greatly appreciated. I need to program my key fob.
What I have:
  • the original key (without a working fob)
  • a second new key (from VW with an unprogrammed fob)
What I tried:
I have the other instructions posts on this platform with no luck. The main article that that I followed gave me the instructions below, but they do not work does not work.
1 - turning the car on and leaving it running with the key I want to program
2 - reaching out of my window and locking the drivers side door with a separate key (no fob on it)
3 - pressing the unlock button on the key that is in the ignition
4 - waiting six seconds and pressing the key that is in the ignition again
Waiting 30 seconds,turning the car off and trying the fob. Doesn't work. Please help!
2015 TDI Exec R-Line
You’ll need VCDS to program the remote functions, and either VCDS with the SKC or ODIS with a GeKo account to program the immobilizer portion of the fob.
Ah ok thank you! So basically there isn't actually a way to do it on my own?
Do you know why the other posters thought there was a way to do it on their own?
Thank you 🙏
They were wrong?
For your 2008, you have IMMO4c which cannot be programmed with VCDS, you need ODIS and a GeKo account. Basically dealer only unless you know someone with some nefarious software.
2013 7P Touareg R line V8 4.2 TDI
Just to clarify... If you have no working Fob you need the dealer as stated. If you had a working FOB an auto lock expert with the right gear could code a new one
Discussion Starter · #7 ·
@chewblekka two follow ups (just seeing if my old key is dead)
1 - if the battery is working and the key is functioning, should a red light appear when the buttons are pressed? even if its not programmed?
2 - will removing the battery lose the programming information?
Thank you!
LED will illuminate regardless of programming. The immobilizer part is a RFID chip that has no battery, it won’t lose programming. The keyless part should retain programming too.
Discussion Starter · #9 ·
[/QUOTE]
Thank you!
It turns out my backup was programmed but the battery was dead. The main one was just dead due to taking a swim.
But at least now I can program a new one easier - thank you so much for your time!
1 - 9 of 9 Posts
