I accidentally lost the knob that fits on the center console that allows me to rotate my side mirror. Turns out, VW only sells the entire assembly for $160 plus 1-2 hours to install. I was hoping that there is a kind soul that can direct me to where I can simply buy a replacement knob? Thank you, Jeff
Yes, heater is at the bottom and L O R are up above. I think the post is okay if I had the correct replacement knob. Thanks!
My Touareg mirror switch nob falls off all the time and fortunately I always find it between my feet. I don't think you can buy just the nob. I believe you will find online sellers of the complete switch and nob for around $110.
I believe this is the correct part number: 7L6-959-565-K-3X1 although I would double check with a dealer using your vin number .
You can always try some wreckers for just the nob.
