1 - 2 of 2 Posts
Hey guys,
My left rear door speaker is making this really annoying rattling sound. I wanted to have a look at the speaker to see if it may be blown. However, I don't know how to remove the grill. Do I have to remove the entire door panel? I tried prying the grill off with a flat blade screwdriver. One of the corners popped out, some sort of plastic pin, but now it looks broken. Are these grilles one way? Or was I just unlucky to break the pin?
I decided to ask here first before destroying more parts :p
Thanks in advance for any advice you may have.
(My Treg is a 2004 V6)
This Web page give a good explanation on ho to remove the door trims, once inside you should be fine...
- Volkswagen TDI (2x) -: (T2)
I don't think you can remove the grilles from outside without destroying them
Stuart..
1 - 2 of 2 Posts
