1 - 3 of 3 Posts
Hi guys,
I am trying to remove the "wood" cover on the back of the center console.
Any suggestions? Could I just pry it off without any damage?
btw, I did the search and came up empty
try spockcats ignition button thread. In it one of the first steps is to remove the top of the centre console its self. This might let you see inside toward the back and where you need to get to.
I cant remember myself when i had mine off but you should be able to inspect and determine if you are going to break anything or not.
Thanks Odessa,
I just got that trim off - it's just a matter of carefully prying starting on the bottom side.
Then there is access to them screws.
Was so worried breaking it.......
1 - 3 of 3 Posts
