What is the recommended frequency of front diff lube change on the '04?? Of course I believe VW says its "Lifetime..."
Thanks--
--Karl
Somewhere near Seattle
Change front and rear diff oil and transfer box oil and the ATF in the gearbox every 60,000 miles, or sooner if you tow something big and heavy for a lot of the time.
Learner
From my experience use original vw oil
Thanks for the replies. I am wondering if the problems with metal found in front diff oil and front diff failures in older cars (like mine) can be attributed to breakdown of oil. any thoughts or experiences...??????
Thanks--
--Karl
2004 T1 V8
113,000 miles
LOW oil level - as in leaking seals - can certainly cause differential gears and bearings to wear and overheat and that overheating can, in turn, degrade some of the properties of the oil but it is unlikely that the oil would degrade first and THAT would be the primary cause of the failure.
