Is anyone aware of a fix to a leak INSIDE the car?
I have read a similar thread, where the fluid was leaking outside the car, when the washer isn't in use: http://www.clubtouareg.com/forums/f43/rear-wiper-washer-fluid-leak-76915.html
Here's what happened...
Both the front and the rear squirters weren't putting out much fluid, so, thinking that my level was low, I filled the reservoir with 1 gallon+ of RainX wiper fluid. I then tried to use the rear squirter, only to find just a dribble of fluid coming out onto the window. I thought maybe it was the cold that froze things up, but when the weather warmed up, I got the same result - I tried and tried to no avail.
Then I got a low fluid indicator, with no fluid on the ground! What the...??
Over the next few days I smelled something strange when I got into the car, and couldn't figure out what was going on. Finally I opened up the hatch, lifted the cover, and what did I see but a pool of RainX fluid to the rear of the spare tire - INSIDE the car!
As I took the spare, the air compressor and the jack out, I found more and more fluid. The spongy material to the right of the jack (between two levels of metal) was soaked.
I'm not quite sure where to begin, but I'm not really interested in paying a dealer mechanic $99/hour to figure things out.
Help!
Help!
