1 - 3 of 3 Posts
2006 Touareg v8, rear window keep releasing after closed, latch it then 5 to 10 second, unlatches again? help
I don't know the answer but I am having the same problem.
After I washed the car back in November it behaved in exactly the same way but the next day was behaving itself.
The car got washed again last week with the same result but this time it is absolutely refusing to lock at all.
This must mean water has been getting somewhere it should'nt and this time it is terminal. I need to find how to get access to the wiring to see if anything is obviously corroded.
Sounds like the rear glass switch is duff - a known problem.
You can get the complete new black triangular assembly that sits on the outside of the glass with its switch for less than £27
Part number 7L6 845 227 E. It is called a "TASTER".
I have one sitting on my desk as I type awaiting fitment.
The rear wiper arm is a beggar to remove despite applying WD40 to ease the arm on the shaft so the little garage nearby is going to do it for me - a 10 minute job.
1 - 3 of 3 Posts
