1 - 2 of 2 Posts
Just discovered a leak issue in the rear hatch that seems to be from the upper left corner of the rear window.
Off to a glass shop this week, hopefully covered under the extended dealer warranty.
How common is this?
Very common on my 2008 it leaked and there are tons of threads on rear hatch leak. But if your molding looks fine it could just need adjusted. I'm not sure if the 2011 has the same setup as the T2. I had to simply adjust the screws for the hatch and that solved my issue. Good luck
1 - 2 of 2 Posts
