Hi
A couple of days ago I opend my window hatch as I often do.
But when I closed it, it didn´t lock.
When pressing the button I hear a klicking sound under the roof trim:
When pressig the hook down so it touches the relay the trunk lights go out and the MFI thinks the window is closed:
So I think the relays are OK. Didn´t manage to get the trim of to look at the cables.
Any help?
My God,it's full of stars
Sensor is foobared.
siberian
On same note-my tailgate closes but there is no more motorized assistance which would pull it in and close. Would this be rellay maybe? No scan codes appear.
More likely the sensor doesn't see the proximity to enable the last pull in, as there is no separate relay (that I know of). So since your hatch closes ergo the relay works.
siberian
So, I got all the trim away and took out the lock motor. It was just jammed. Pulled the cylindrical arm out manually and then it started to work again. Installd it again and put back the trim. Now it works fine.
Getting trim flush on and of without breaking any clips is just a bitch.
