So it appears the auto dim feature of the rear mirror isn't working (or not as well as I remember).
Any ideas?
Do they go bad or is it a setting in VCDS I can adjust?
Are you sure it’s turned on? Button on bottom of mirror turns auto dimming on/off
No. I wasn’t sure. But I am now.
That was the problem. Apparently the stealership turned it off when they did work on my vehicle a few weeks ago, but I wasn’t aware it had a physical on/off switch.
Thank you for the information.
Glad it’s working
lolz. In your defense, that little button is pretty hidden.
No VCDS adjustments or canbus connections. The mirror is a self contained unit, which you will find is made by the same OEM used by other car makers. It does have a output wire that supplies power to run the optional external auto dimming door mirrors found in some model years.
About this Discussion
3 Participants
nickyt
Club Touareg Forum
Full Forum Listing
