1 - 4 of 4 Posts
Hi, The RH Rear door on my 2008 Touareg won't lock at all when using the remote locking, or when using the key (in either front door).
I can hear the lock mechanism make a noise, but am unsure right now if it is exactly the same as I'd hear on the LHS rear door. Basically when the rest of the car is locked, i can walk up to the RH rear door and open it easily (without the key fob nearby) which sets off the alarm. Note that i have key-less entry.
What should i do next?
Discussion Starter #2
Hi All,
I've had a look on ebay and note that non Kessy replacement door lock units are very cheap. However those with Kessy function are horrendously expensive. If i installed a non kessy type, would central locking still work?
Would the only downside be that i can't walk up to that particular door and open it unless i use central locking - to me that is very minor and well justifies the $200+ saving.
Keen to hear from you.
Thanks,
I honestly don't know. Knowing these vehicles, I feel that it would probably be kind of unhappy to not have the non-Kessy module with all of the Kessy ones. Best case would be as you described, with Kessy only not working on that one door.
Hi All,
Thanks,
Hi
Did you end up replacing your lock with a non kessy lock? I tried but the kessy has a 9 pin plug while the non-kessy is 7. Would be interested to know how you got around this.
Norm
1 - 4 of 4 Posts
