Mine is a 2007 but should be the same. Mines been kinda finicky so I just took mine out to see if I can clean the contacts or something. Just take a small screwdriver and carefully pry on one edge. Once that side pops out work your way to the other side. The connector is one of the easy ones... Just push the tab at the top of the connector body.
In case I replace this switch, do you have a part number and how much do they run? Thanks[/QUOT
The cost of the switch is about $45. I will post the part number when the switch comes into my dealer for me. Thanks for the reply and photo!
