1 - 8 of 8 Posts
Hi i'm trying to add rear fog light on my 2013 Touareg. I have follow instruction of ppozo, very good work, but it only activate left rear fog. I have try activate right rear fog using chanel 204.
Now i have 5 trouble code
Address 46: Central Conv. Labels: 4H0-907-064-46.clb
Control Module Part Number: 4H0 907 064 CK HW: 4H0 907 064 CK
Component and/or Version: BCM2 2.0 H33 0433
Software Coding: 0306163A28B9509582A00620210000000000000000000000000000000000
Work Shop Code: WSC 31414 790 00001
VCID: 74A42BF7D79AFFEAC9-8020
5 Faults Found:
03389 - Data Set Implausible
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 208478 km
Time Indication: 0
Date: 2019.04.20
Time: 16:52:43
03532 - Left Brake / Signal Light Lamp 2
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 208478 km
Time Indication: 0
Date: 2019.04.20
Time: 16:54:45
03533 - Right Brake / Signal Light Lamp 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 208478 km
Time Indication: 0
Date: 2019.04.20
Time: 16:54:45
03554 - Left Brake Light Lamp 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 208478 km
Time Indication: 0
Date: 2019.04.20
Time: 16:54:45
03555 - Right Brake Light Lamp 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 208478 km
Time Indication: 0
Date: 2019.04.20
Time: 16:54:45
Also display show me trouble with tail brake light left and right also vehicule lighting trouble
I have remove all new adaptation done still 5 touble code and 3 trouble displayed
Any idea
Fred
Do you even have a right rear fog light to turn on? On my right hand drive 2016 T4 there is only a single rear fog light on the right.
Hi i have found a image from VWFREEKALEEK about channel coding and dismantle all code... it can help lot of us
first number are bit to write
second is action made by J393
third (is channel to write into)
forth in addition of bit
0 nothing
1 on
8 rear fog
9 rear fog light left L46 (203) 1+8
12 back-up
13 back-up left M16 (205) 1+12
32 right side
41 rear fog light right L47 (204) 1+8+32
45 back up right M17 (206) 1+12+32
5124 tail, brake
5124 tail, brake left M21 5124
5156 tail, brake right M22 5124+32
13832 tail, brake, turn left M69 (195)
13836 turn
13836 rear turn left M6 (207) 13836
13864 tail, brake, turn right M70 (196)
13868 rear turn right M8 (208) 13836+32
51201 tail 2 left M49 (197) 51210 tail 2, rear fog left M41 (197)
51215 third brake M25) (212)
51233 tail 2 right M50 (198) 51274 tail 2, rear fog right M42 (198)
Fred
0 nothing
1 on
8 rear fog
12 back-up
32 right side
5124 tail, brake
13836 turn
Fred
Can you make anymore more clarity for this? I'm having rear fog coding issues.
Sent from my HD1907 using Tapatalk
Discussion Starter #8
Hi so JCstomper for rear fog light in channel 203 you put 9 (1 is switch channel on and +8 is rear fog light) so the left one will light up and in channel 204 you put 41 (1 is switch channel on, +8 is rear fog light and +32 is right side) so the right fog light will light up...
The detail of what a wrote is (channel number) 1+8 are line starting with # explication
1 - 8 of 8 Posts
