2013 VW Touareg Bluemotion 150kw Stage 2 tune, TAG towbar, Titan Suspension coilovers
I got my 2013 7P 4 weeks ago and had a TAG towbar fitted with Towpro electric brake controller. I also have a Raptor adjustable tow hitch to achieve whatever towball height I need.
Hitching up to my caravan for the first time, I noticed quite a bit of sag on the rear of the Treg and the nose of the caravan pointing down as a result. Is the sag an issue as I have steel springs and no air suspension. Reading other threads most seem to think sag is acceptable and putting in stiffer springs is not recommended as it makes the ride jittery when not towing.
I have the Alex G 2” lift kit on order to get more clearance for sand driving. This will lift the car and I may also raise the Raptor hitch to lift the nose of the caravan. The rear will still be sagging and front pointing skyward but I can get the caravan level. Will this work?
