Yesterday when starting the car the idle was really rough, the whole car
started to shake. The RPM goes up and down when idling.
CEL light flashing.
I put some throttle to it and the shaking stopped. Started to drive.
2-4 gear no problem but when I hit 50 km/h and it goes into 5th gear
it started to stumble.
When I came home i ran a scan with vag-com and got the following codes.
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
16685/P0301/000769 - Cylinder 1 Misfire Detected
16690/P0306/000774 - Cylinder 6 Misfire Detected
When looking on Ross-tech wikki about possible causes I can see that the fualt codes have one common thing.
That is: EVAP canister purge valve!
Do you think it will fix the problems by just change the EVAP purge valve N80?
CEL light flashing.
