1 - 14 of 14 Posts
I have just started the process of dismantling my 07Z903021F 14V 190A alternator.
I had fried the rotor after second install.
A loose diesel return line allowed diesel to leak and touch the 12 volt alternator connection which killed it immediately.
The first give away of trouble was melting plastic smell, followed by voltage drop to 12 volts, excess diesel smell after test run. As the leak was from the return to the tank there were no performance issues from the engine.
Being short of funds and wanting to be more V10 independent. I decided I might just as well try and repair this unit while I saved for a replacement. It is already stuffed.
My Autolec friend test the alternator and found the rotor was the problem.
I will provide photo's of my progress.
Currently the rotor has been dismantled and I am setting up a jig to count the number of turns for replacing the wiring on the spool.
I will update with correct component id etc, but I just wanted to also hear from any other members that may have done this before.
Proper DIY going on here. Fingers crossed it works.
I used to have a 90 year old car and when the magnetos needed work the little man I used used to cook his windings in the oven in his kitchen [and his wife didn't mind!].
Discussion Starter · #6 ·
Thanks all, I found a wire winder that has the counter etc. I am also cross referencing with the rotor size with Delphin ,Delco with other vehicles. Some of the Mercedes 190 amp Alternator rotors i have checked have the same measurements and specification that the V10 rotors use I will lodge my findings as I go to help others to keep costs and reliability at there best. I love my V10 and reliability cannot be trusted to others.
I will have a break over the New Year but all my work on the system I will post. Merry Xmas to all, may it be, safe, happy and inspiration .
Happy holidays to you too.
Discussion Starter · #9 ·
Sorry for not following up on my progress how i went with rewinding. due to a number of basic mistakes I made during dismantling I have had to postpone the rebuild.
The show stopper was damaging the magnets which are set in between the north and south jaws of the rotor.
The magnets are very brittle and I damaged 3 of them which I cannot find replacements.
The replacement alternator for my Delphi unit was an Hitachi unit, and that process was not a quick plug and play I will list under my adventures under separate posts ,
"Substituting 2005 V10 Delphi to Hitachi alternator " the modifications that will need to be done to make this work.
" Common rail fuel "O" ring replacement installation and testing for leaks before completing total alternator installation.
After 2 failed O ring leaks which ment I had to dismantle twice back to alternator. The leaking fuel was only detected once full assemble and engine started.
The positives are that my mistakes will allow others to do it easier the other positive is that I am bloody fast now at replacing the alternator. I can do it in a 1/3 of my first time.
I will complete both postes by next Thursday. I will start on Monday.
V10 is going great, have added performance chip waiting to measure improvements. There is a difference.
Black 2004 V10
What type of performance chip did you use?
What's wild is that a USA chain of car parts stores, O'reilly Autoparts now lists rebuilt Delphi and Hitachi alternators for the V10 TDI!!!! for around $270USD ! Cheap! I actually went to the parts store and verified in person that the mfg's were delphi and hitachi. I plan to get a new alternator and not rebuilt... but for that low of price might get an extra as a back up. Already replaced mine once.
https://www.oreillyauto.com/shop/b/...b2ae3cc0/2004/volkswagen/touareg?q=Alternator
1 - 14 of 14 Posts
