1 - 14 of 14 Posts
Good day...
You and most R5 drivers in South Africa ;)
Here they are scares, but pop up now and then.
A friend of mine found one for me by accident.
I would contact scrap yards, gumtree and independent workshops that work on touaregs.
Yes, that's what I am finding, I have tracked one wheel down in the UK (where I brought it originally - have now imported to Oz) but need wheels a bit closer, hopefully. I have spent a fair bit of time looking around for them ontinternet but nothing so far. Seen plenty of 5x130's
Jip. Took me ages to find one. I went one size bigger on the rubber to 265/65 R17 so the biscuit could no longer be used.
I luckily found a canyon 5x120 rim (same as my factory rims) and I Now keep it on the roof rack. (It takes too much space in the boot)
I am proud of my attachment method - it doesn't move but as an added safety I have used a ratchet strap as well.
Yep, that's what I have done, gone for 265x65's. Will cross the on top/Back/Inside bridge when I get there in terms of carting the spare about. Yep the biscuit is a lame excuse for a spare. Also installed Seikel suspension which is the dogs!
I have two 17 inch rims and tyres spare if they fit??? they fit my 2009 treg and have 255/60/17 tyres onboard with 20% tread left.
If they are from your V6 then they are the wrong PCD 130 mm , these guys need 120 mm
Reactions: Magicbola
I have a new wheel and tyre from my 2006 T1 R5 and am in Adelaide.PM me if interested.
R5 rims are canyons
17"
ET55
5x120 PCD
7.5J
as long as the offset and rim width is close. Else you mess up the suspension geometry.
1 - 14 of 14 Posts
