1 - 18 of 18 Posts
Posting for someone else regarding a Q7 TDI.
Does anyone know if this service builtin applies to 2015 as well?
Symptoms are TPMS & Air suspension codes on at the same time.
VCDS scans below:
Sunday,26,April,2020,21:12:57:50234
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WA1WMBFE8FD004953 License Plate:
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Control Module Part Number: 4F0 910 274 B HW: 4F0 907 274
Component and/or Version: J793 RKA+ H04 0110
Software Coding: 0758733
Work Shop Code: WSC 31414 790 00001
VCID: 2313EC36C7D9BBB36E9-8076
4 Faults Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 3
Reset counter: 186
Mileage: 115339 km
Time Indication: 0
Date: 2020.02.26
Time: 08:07:45
Freeze Frame:
Hex Value: 0x0001
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.30 V
Temperature: 1.0°C
(no units): 76.0
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 8
Reset counter: 191
Mileage: 115575 km
Time Indication: 0
Date: 2020.03.19
Time: 13:22:57
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 10.60 V
Temperature: 27.0°C
(no units): 0.0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 191
Mileage: 115575 km
Time Indication: 0
Date: 2020.03.19
Time: 13:22:57
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 10.60 V
Temperature: 27.0°C
(no units): 0.0
01310 - Level Control System Control Module (J197)
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 25
Reset counter: 153
Mileage: 115279 km
Time Indication: 0
Date: 2020.02.25
Time: 08:02:27
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0005
Voltage: 13.30 V
Temperature: 5.0°C
(no units): 0.0
Address 4C: DTCs cleared
Address 34: Level Control Labels: 4L0-910-553.lbl
Control Module Part Number: 4L0 910 553 J HW: 4L0 907 553 E
Component and/or Version: LUFTFDR.-CDC H04 7860
Software Coding: 0015520
VCID: 313F167E8D251923EC5-8064
1 Fault Found:
02645 - Valves for Level Control System
003 - Mechanical Failure
Freeze Frame:
Fault Status: 11100011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 115899 km
Time Indication: 0
Date: 2020.04.26
Time: 21:09:11
Freeze Frame:
Error Code: 141
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 115899 km
Time Indication: 0
Date: 2020.04.26
Time: 21:09:11
Freeze Frame:
Error Code: 141
Address 3C: Lane Change Labels: None
Control Module Part Number: 4L0 910 566 C HW: 4L0 907 566 B
Component and/or Version: J0769_SWA_MasterH03 0050
Software Coding: 0010001
Additional Info: 4L0910568C J0770_SWA_Slave_H03 0050
Additional Info: Geraet 00001
VCID: 2E050D029C1B06DBF17-807A
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 2
Reset counter: 191
Mileage: 115852 km
Time Indication: 0
Date: 2020.04.19
Time: 18:38:40
02857 - Supply Voltage for Lane Change Assistance Control Module 2
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 191
Mileage: 115852 km
Time Indication: 0
Date: 2020.04.19
Time: 18:38:40
Sunday,26,April,2020,21:35:25:50234
www.Ross-Tech.com
1 Fault Found:
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 193
Mileage: 115899 km
Time Indication: 0
Date: 2020.04.26
Time: 21:29:40
Freeze Frame:
Error Code: 141
www.Ross-Tech.com
4 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 186
Mileage: 115339 km
Time Indication: 0
Date: 2020.02.26
Time: 08:07:45
Freeze Frame:
Hex Value: 0x0001
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.30 V
Temperature: 1.0°C
(no units): 76.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 191
Mileage: 115575 km
Time Indication: 0
Date: 2020.03.19
Time: 13:22:57
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 10.60 V
Temperature: 27.0°C
(no units): 0.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 191
Mileage: 115575 km
Time Indication: 0
Date: 2020.03.19
Time: 13:22:57
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 10.60 V
Temperature: 27.0°C
(no units): 0.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 25
Reset counter: 153
Mileage: 115279 km
Time Indication: 0
Date: 2020.02.25
Time: 08:02:27
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0005
Voltage: 13.30 V
Temperature: 5.0°C
(no units): 0.0
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 115899 km
Time Indication: 0
Date: 2020.04.26
Time: 21:09:11
Freeze Frame:
Error Code: 141
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 115899 km
Time Indication: 0
Date: 2020.04.26
Time: 21:09:11
Freeze Frame:
Error Code: 141
North American Touaregs beyond the first few generations do not have air suspension, so I am not sure how much input I can offer. If the TPMS module is anywhere close to how it is set up in a Touareg, it will be directly behind the rear control arm. They literally could not give it more saltwater exposure if they tried. Mine failed and was "repaired' by the dealer twice. It subsequently failed outside of warranty, with wires corroded over 30 cm back. I would absolutely check to at least verify voltage at the TPMS module. One wire should be +12V, one should have continuity with ground, while the remaining two wires should be at 2.3 and 2. 7V for CAN low and high repsectively. This is with key on, engine off.
From what i can see on your scan, VCDS indicates a mechanical faullt with the air suspension. Unless I am reading incorrectly (very possible), you are communicating with the suspension module, but the module is indicating that something is wrong ....
I suppose I should mention the low voltage in the VCDS scan was probably due to a dead battery a day or two prior. I'll take a look at the module and see if it has any corrosion etc... on it.
The air suspension DTC has nothing to do with CAN-bus. There’s a mechanical issue with the valve block (stuck valve most likely).
Get the battery sorted out. Either fully charge it or replace it.
Are you asking if you have 3 bad modules all at the same time <or> if the signal wire is bad. I think you can do the math on that one. Two modules would be a fluke. Three is like winning the lottery twice.
Anyway, fix the battery, clear the codes, run a few trips and report back with what codes have came back.
The second scan on a fully charged battery, connected to a battery maintainer, after clearing codes; is the only scan that really matters.
2x on fixing the battery, things start acting wonkey and throwing faults before the battery actually gets bad enough it wont start.. IIRC when my original battery went I was getting weird Air Suspension lights, the power hatch would not work w/out engine running, mmi was cold booting, and a few other issues that were electrical in nature.. this went on intermittently for a month, the faults would go away for a few days and come back after a start.. then one very cold morning the car didnt start, so I put a new battery in and all those weird phantom issues I had the month before just vanished into the ether.
The Air Suspension works w/out the engine running, you can get it to lift/level/etc all just with the key in the ignition, heck it auto levels w/no key or anyone in the vehicle.. so those faults could be the result of improper voltage for correct operation when the engine was not running.
Battery was replaced. All codes were cleared. Here is what is remaining:
Scan of Module 34 Level Control:
Sunday,03,May,2020,21:53:02:50234
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 158
Mileage: 115991 km
Time Indication: 0
Date: 2020.05.03
Time: 21:37:31
Freeze Frame:
Error Code: 141
Scan of TPMS:
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 158
Mileage: 115991 km
Time Indication: 0
Date: 2020.05.03
Time: 21:37:31
Freeze Frame:
Error Code: 141
Scan of everything:
Sunday,03,May,2020,21:44:28:50234
www.Ross-Tech.com
Mileage: 115990km-72072mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 34 36 3C 42 46 47 4C 4F
52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1WMBFE8FD004953 Mileage: 115990km-72072miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
Component: 3.0TDI FSA H23 0014
Revision: 54H23--- Serial number:
Coding: 2A2A4012253600050000
Shop #: WSC 17001 004 1048576
ASAM Dataset: EV_ECM30TDI0114L2910401A 001015
ROD: EV_ECM30TDI0114L2910401A.rod
VCID: 221DE932D443B2BB65F-8076
No fault code found.
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ
Component: AL1000 AISIN 002 3399
Serial number:
Coding: 00B378
ASAM Dataset: EV_TCMAL991031 002115
ROD: EV_TCMAL991031_002.rod
VCID: 7BA3F45613692373069-802E
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0103537
Shop #: WSC 31414 790 00001
VCID: 34311F6A72372C0B873-8060
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702149378
Coding: 0000135
VCID: 2517F22EC9ED458300D-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H04 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000000439568
Coding: 0304A036
VCID: 2517F22EC5ED458300D-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0106997422
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0106997334
Coding: 070000
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0133123
VCID: 6E85CD025C9B46DBB17-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55931418100579
Coding: 29011F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 34311F6A7EB72C0B873-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 72 AIRBAG AUDI8RH45 0230
Revision: 09H45000 Serial number: 0038QD907YT0
Coding: 0014130
VCID: 2B030416AF0973F3D69-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME1D430F70I
Subsystem 3 - Serial number: 6342QSME1A434A40C
Subsystem 4 - Serial number: 6352QSME044645707
Subsystem 5 - Serial number: 6362QSME004658449
Subsystem 6 - Serial number: 63734SME0152514AT
Subsystem 7 - Serial number: 63834SME34454E4A7
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026141470285
Coding: 0012142
VCID: 2809FB1ABEFF58EB3BB-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 Q HW: 4L0 920 985 Q
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2S43L97F
Coding: 8BD664040901CF05020205
VCID: 42DD49B2348392BB05F-8016
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M146270415
Coding: 00C303
VCID: 3FDB40464771FF536A1-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 41178831024121471997
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---011 Serial number: 00000030343525
Coding: 0000006
VCID: 6889BB1A7E7F98EBFBB-803C
Part No SW: 4L0 910 553 J HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7860
Revision: --H04001 Serial number: 15.1528-0143.2
Coding: 0015520
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 158
Mileage: 115991 km
Time Indication: 0
Date: 2020.05.03
Time: 21:37:31
Freeze Frame:
Error Code: 141
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000104808554
Coding: 00581B00000011110000
VCID: 323D19728423223B95F-8066
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 009 014-10
Coding: 0010001
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H03 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F22.06.1400H03000AMS14873ÿ
Subsystem 4 - Serial number: S14873ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000110140731
Coding: 011F57205E40440004
VCID: 48C95B9A12BFB8EBDBB-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82006164220000
Coding: 3569949
VCID: 38292B5A6E5FC86BABB-806C
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 466 A HW: 4L0 035 466 A
Component: BO Q7 H30 0110
Revision: 07S00000 Serial number: 01903140008068
Coding: 0D000001
VCID: 290FFE1EA9F561E3245-807C
Subsystem 1 - Part No SW: 4L0 910 465 A HW: 4L0 035 465
Component: BO Q7 SLAVE H41 0780
Serial number: 00705140021114
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191062427
Coding: 0758733
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 158
Mileage: 115991 km
Time Indication: 0
Date: 2020.05.03
Time: 21:37:50
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0071
Voltage: 13.20 V
Temperature: 23.0°C
(no units): 0.0
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000190259
Coding: 0012001
VCID: 5EE59DC2AC3BD65B017-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000110148353
VCID: 47CB58A61FA1B793D21-8012
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000032
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156G 0E8032565
Coding: 020007010000000000
VCID: 2411EF2ACED7BC8B173-8070
Part No SW: 4L2 035 746 F HW: 4L2 035 746 D
Component: H-BNT-NA H41 0812
Revision: -------- Serial number: 224GW0EB004561
Coding: 180200060004F3EF510023456F632003140000000100000000
VCID: 313F167E81251923EC5-8064
Subsystem 1 - Part No: 8R0 060 884 CA
Component: NAR 2014 1002
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130GX0E3076745
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002193603
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000109779260
Coding: 010E57204040230004
VCID: 46D555A218ABAE9B297-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00008200542294
Coding: 0200000000000000
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0164531
Coding: 020C000001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6E85CD02501B46DBB17-803A
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H58 0500
Revision: --H58001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81C70A6A87B4CB9F3-8038
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: 1 ó
Subsystem 3 - Serial number: RD07.07.14--H58001002G0161ÿ
Subsystem 4 - Serial number: 2G0161ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0110071752----
Coding: 0003595
VCID: 2615F522B4EB4E9B097-8072
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H15 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H15 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H15 0220
1 Fault Found:
02961 - Lamp in Bumper; Rear Right
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 158
Mileage: 115991 km
Time Indication: 0
Date: 2020.05.03
Time: 21:36:53
Freeze Frame:
Bin. Bits: 000 100
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000109779261
End----------(Elapsed Time: 02:13, VBatt start/end: 13.7V/14.2V)-----------
Looking at the TPMS it seems it set an error code based on the Air Suspension Code.
Looking at the Air Suspension, we have a single code to track down.
Everything below is from Ross-Tech.
Possible Causes
  • Wiring issue between G291 sensor and J197 Control Module
  • Faulty G291 sensor
  • Faulty J197 Control Module
  • Air leak in system
Possible Solutions
  • Inspect and repair wiring harness
  • Inspect for leaks with soapy water
Additional Notes
  • When found in the VW Touareg, see Technical Bulletin V4305XX
  • When found in the following Audi vehicles check TSB 43-08-16 | TPI 2018765
    • 2006-2009 (4F) A6
    • 2004-2009 (4E) A8
    • 2007-2009 (4L) Q7
      • May be stored in conjunction with one of more of the following faults 00453, 01583, 01770, 01772 and/or 02646.
  • Also see TPI 2033587 and/or TPI 2022462
VW TSB
Discussion Starter #11
Initially I thought a faulty valve block. But now I’m questioning whether it’s a valve block, pressure sensor or control module.
What confuses me is which it is?
As far as I can tell J197 is the electronic control module in the rear electronics rack.
It appears VCDS is communicating with the module. Perhaps driver circuits have failed? If so how would that be determined?
G291 appears to be a pressure sensor. Is it part of the valve body or a separate part?
Any chance this is a wiring isssue?
Thanks in advance.
When researching Air Suspension pre-purchase of my Q7 it seemed like the Valve Block was a common failure point on these, there's youtube videos on replacing it and tons of threads on google.. I get intermittent codes in the winter time from the air suspension, its like there's a lil moisture in the air system and the valves stick/freeze.. they all go away once it warms up.. I think this sensitivity to throwing faults is what makes the Air Suspension in the Q7 more reliable than say the old All Roads.. its smart enough to realize something is not right and wont destroy its self burning up pumps and solenoids fighting a broken system and making things worse and more expensive... I usually catch a thermal shutdown once or twice a summer too because it thinks the pump is too hot.
Been reading a little bit on this.
1. Make sure the air compressor relay is good.
2. First match was fixed by replacing the compressor. Although it tested good, it was weak. Even with a rebuild kit, it was not coming up to max pressure fast enough.
3. Second match was fixed by freeing a front level sensor that had got sticky and binding.
4. It seems there are multiple problems that can lead to this particular error being set.
The 003 mechanical failure error is just the computer saying that the system is not coming into spec as fast as it should.
I have never seen a valve block go out on the pre 2010 Touaregs. I have no idea how dependable they are on later years, although it is hinted above that they are not dependable.
So, NTDI will have to do some more researching to find the cause of the problem. It can be many things. When you are looking for solutions, try starting with this google search string "02645 - Valves for Level Control System 003 - Mechanical Failure site:forums.ross-tech.com"
dreadlocks, it sounds like your pump is about to die. Between the overloaded dryer desiccant and the thermal overloads, I would consider not rebuilding but replacing your compressor.
yeah I figured the pump was going, its $850 for an Arnott P-2496 OEM pump and everything is working perfectly fine right now, just a couple random faults that have been there for years now and never really noticed any issues other than the faults in the memory and very rare lockouts when its suddenly really damn cold.. so I'll ride it til it dies, wont rebuild it but wont replace it early unless it goes into lockout mode more than a couple times a year or something.
When I do the brakes I check out the level sensors and make sure they are all cleaned up, perhaps I should hit em with a lil grease next time if those tend to seize up.. they are always covered in mud.
Discussion Starter #17 (Edited)
Also wanted to share the following link:
Air Suspension related Bulletins (from link above):
https://static.nhtsa.gov/odi/tsbs/2013/MC-10123921-9999.pdf (cold weather related errors)
https://static.nhtsa.gov/odi/tsbs/2017/MC-10128322-9999.pdf (extreme cold weather related issues)
https://static.nhtsa.gov/odi/tsbs/2013/SB-10066877-6903.pdf (extreme cold weather related issues, can not adjust suspension in extremely cold weather)
https://static.nhtsa.gov/odi/tsbs/2013/MC-10128036-9999.pdf (Vehicle Lowers After Startup)
https://static.nhtsa.gov/odi/tsbs/2013/SB-10066882-6903.pdf (Vehicle lowers after startup)
https://static.nhtsa.gov/odi/tsbs/2013/SB-10066880-6903.pdf (Various Fault Codes)
https://static.nhtsa.gov/odi/tsbs/2013/SB-10066879-6903.pdf (Vehicle lowers on its own)
https://static.nhtsa.gov/odi/tsbs/2013/MC-10128036-9999.pdf (Vehicle won't level after start)
https://static.nhtsa.gov/odi/tsbs/2013/SB-10066875-6903.pdf (Vehicle sits unevenly or crooked)
I don’t believe the T1/2 have tank drains (there’s 2 tanks as well). On my T3, there’s only a single tank with no drain. There is a nitrogen fill port (R134A high side fitting). The T3 air system is closed and nitrogen filled, so in theory there shouldn’t be any air in the system unless you have leaks.
1 - 18 of 18 Posts
