Enter your required ATM here:3000 | 2200 | | |
Enter ball weight percentage of ATM here: 10 | 10% | Touareg 7P series, 180TDI, sunroof | Touareg 7P series, 180TDI, no sunroof |
Result: Payload remaining after ball weight added | | 266 | 366 |
Tare (kg): the actual weight of the empty vehicle with 10ltr fuel | | 2159 | 2159 |
PAYLOAD: maximum payload specified by the manufacturer | | 626 | 626 |
Kerb weight (TARE + full tank of fuel) | | 2234 | 2234 |
GVM (kg): Gross Vehicle Mass, or the maximum allowable weight supported on the car wheels | | 2860 | 2860 |
Max front axle load | | 1370 | 1370 |
Max rear axle load | | 1520 | 1520 |
GCM (kg): Gross Combined Mass, or if not specified, the published maximum allowable GVM + ATM - ball (ball in the GVM) | | 6415 | 6415 |
ATM (kg): Manufacturer rated | | 3500 | 3500 |
Ball rating (kg) Allowable Drawbar Weight (kg): The maximum allowable downforce on the towball or drawbar | | 280 | 280 |
OTHER PAYLOAD items such as OPTIONS not included in TARE: | | Max roof load likley to be ZERO due to sunroof, space saver spare is no good for towing | Max roof load 100kg, space saver spare is no good for towing |
Payload: Sunroof | | 100 | 0 |
Payload: Fuel (full tank noting TARE will include 10ltr fuel only) | | 0 | 0 |
Payload: Outboard motor if carrying inside the vehicle | | 0 | 0 |
Payload: Full size spare tyre (for space saver equiped vehicles - space saver not legal when towing) | | 40 | 40 |
Check manufacturer numbers | | | |
Stated ATM compared with stated GCM | | | |
So calculated GCM (GVM + ATM - BALL) is: | | 6080 | 6080 |
This is OK? | | TRUE | TRUE |
Margin provided | | 335 | 335 |
Maximum ATM allowable (ATM = GTM+BALL, GTM = GCM-GVM, ATM = GCM-GVM+BALL) but not exceeding manuf. Specs | | 3500 | 3500 |
Your detail: | | | |
ATM(kg): your trailer weight axle plus ball load | | 2200 | 2200 |
Actual Drawbar Weight (kg): typically 10% of the axle loading (GTM) | | 220 | 220 |
GTM (kg): Actual trailer weight (kg) or axle load or what your trailer (and boat) actually weighs on the axle, including everything on or in it | | 1980 | 1980 |
Total Payload (kg): Everything that is not car and trailer, such as driver, passengers, fuel, sunroof, luggage, dogs and everything else not in the TARE | | 140 | 40 |
Errors if any in YOUR ATM detail shown here --> | | | |
1. Can you tow the trailer | | | |
The trailer ATM is within the car spec (allowance = GCM-GVM+BALL) | | TRUE | TRUE |
Allowance is (using "checked" ATM) | | 3500 | 3500 |
The car will support the ball loading (is Ball<=MaxBall) | | TRUE | TRUE |
kg extra margin on the ball | | 60 | 60 |
The car and trailer combined weight is under the car rated GCM (is ATM+Tare+Payload<=GCM) | | TRUE | TRUE |
GCM margin (kg) - Note: this is not payload, there are other factors to consider | | 1916 | 2016 |
2. How much payload in the car after trailer connected if you CAN tow the trailer | | | |
PAYLOAD - calculated from GVM less TARE if not specified | | 486 | 586 |
Payload possible after ball weight added | | 266 | 366 |
ONE PASSENGER FRONT SEAT Remaining payload possible ON REAR AXLE after ball weight ADDED | | 176 | 276 |
TWO PASSENGER FRONT SEATS remaining payload possible ON REAR AXLE after ball weight added | | 86 | 186 |
The following is experimental | | | |
Estimate payloads based on axle ratings | | | |
TARE | | 2159 | 2159 |
PAYLOAD | | 626 | 626 |
KERB | | 2234 | 2234 |
GVM | | 2860 | 2860 |
Tow ball load (user load not max load) | | 220 | 220 |
Apportion Kerb mass to axles | | | |
- Front axle Kerb load | | 1059 | 1059 |
- Rear axle Kerb load | | 1175 | 1175 |
Tow ball load apportioned to axles via WDH | | | |
- Front axle | | 104 | 104 |
- Rear axle | | 116 | 116 |
Kerb plus ball load | | | |
- Front axle | | 1163 | 1163 |
- Rear axle | | 1291 | 1291 |
Front seat passenger payload possible with WDH | | 207 | 207 |
Luggage payload possible with WDH | | 229 | 229 |
Tow ball load apportioned to axles no WDH | | | |
- Front axle | | 0 | 0 |
- Rear axle | | 220 | 220 |
- Front axle | | 1059 | 1059 |
- Rear axle | | 1395 | 1395 |
Front seat passenger payload possible no WDH | | 311 | 311 |
Luggage payload possible no WDH | | 125 | 125 |
