1 - 4 of 4 Posts
Hi
2006 Touareg 3,0 TdI .
my tailgate (boot door) will not close properly.
i have read most treads on the subject but cannot find answer.
I have replaced both the part in the tailgate , and the actuate strikerpin part in the bottom of car.
The lock in the lid itself is a 2 position lock and it will only engage strikerpin at the first position .
i have tried reposition of strikerpin part , no difference .
Seems like striker pin part also is a 2 position , and mine does not move to the extend position , so it can engage both positions on lock kn lid.
when opening or closing the lid (tailgate ) about 2/3 down it makes a sound and striker pin has a short spasm?.
Why will my new strikerpin not move to second position so it can engage the lock properly.
does this make sense ,
i fear a broken wire some where .
the strike pin part has 3 wires to it
plus , ground , and signal
where does the signal wire run to?
thanks in advance
regards
Touareg Kong.
236145
236146
Hi again ,
I did as suggested and downloaded info regarding tailgate.
i must have a broken wire somewhere , i do not want to proceed with this soft close .so i have bought from Vw a manual striker pin, without softclose. Do i need to change coding . And change it to what?
Thank you
regards Eik
Multiple v10tdi owner
(3)2004 V10tdi’s
I don’t know why this fool keeps telling people to download a service manual when he doesn’t have a answer. He like a robot.
the first thing you need to do is confirm if you are getting power to the latch. If not you can run a jumper wire to the latch. It most likely will be best to just to lay a new wire than try to find the break in the harness.
1 - 4 of 4 Posts
