1 - 2 of 4 Posts
gennaro
Discussion starter · #1 ·
I have the following problem. When the speed is reduced between 3 and 2 speeds, an impact occurs. If I brake more aggressively, the impact is not felt at all.
Diagnostics fails the following fault: N443 - pressure control valve 7, 0002 transmission electronics, 12859 P074200 Inverter bypass coupling does not disconnect (00001000 passive / sporadic).
It is a 2012 V6 3.0 TDI model. The oil was changed but the problem remained.
Has anyone had a similar experience?
244198
1 - 2 of 4 Posts
