My air suspension will not go to the Load Level position.
It says "Pressure Tank Filling" in the dash display, but I don't hear the compressor running and I have verified via VCDS that the compressor is NOT being commanded to run, either.
I just had the compressor and pressure sensor swapped out because an air line blew out that was connected to the cylinder head assembly. I ran the adaptation on the Level Control Unit just in case, but there is no change.
The suspension also takes a long time to go both up AND down (longer than before the air line blew out and I had to replace the compressor), but it does go from Auto Level to Extra Height eventually. But it will not go to the Load Level position due to the error message.
Any thought? TIA!
Any thought? TIA!
