Hi please can someone help, I have a slow power steering oil leak and have now spotted the one of the metal pipes in front of the radiator towards the bottom has oil running accross it. My problem is I can’t find out what this pipe is called to purchase and replace. Also if you guys can tell me what the two pipes are for?
First, If not 100% sure, clean off the area and monitor for the leak to reappear.
Second. The power steering pump is picky. Don't use an universal fits everything import fluid. You will regret it. Find out which fluid is specified and use any fluid that is listed as compatible with that spec. Repeat: The power steering pump is picky and will start to moan and groan if you put an universal fits all fluid in it.
Luck.
