1 - 2 of 2 Posts
I had this problem recently and couldn't find the answer easily, so I figured I'd post my solution in case anyone has a similar problem.
My power rear door was only opening about 1/2 way. I thought it was going to be another electrical demon, but the dealer suggested this solution.
I guess there is a way to set the limit of how far it opens (in case you're extra short I guess). I had accidentally set it to open about 1/2 way. What you have to do to fix it (or to set it lower if you want) is open it manually to where you want it then hold the button for several seconds and it will set that as the limit. I guess there is supposed to be a beep, but I never heard anything.
Hope this helps before anybody else starts tearing their hair out like I did.
Thanks for that info. Silly question -How do you open it manually? When I press the button under the door it opens electrically.
1 - 2 of 2 Posts
