1 - 20 of 20 Posts
Administrator
The purpose of this thread is for users to post the output scans from your Touareg2 using the VAG-COM. We can use the information to compare controller codings and to gain insight to new coding options for our vehicles.
Administrator
Discussion Starter · #2 ·
From user Siberian:
Friday,06,March,2009,11:57:35:17415
VCDS Version: Release 805.3, Data version: 20090213
Chassis Type: 7L - VW Touareg
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36 37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGBE77L********* Mileage: 22070km/13713miles
Address 01: Engine (BHK) Labels: 03H-906-032-BLV.lbl
Part No SW: 03H 906 032 S HW: 03H 906 032 S
Component: T-GP LEV2 G 1558
Revision: 5FH04--- Serial number: VWX3Z0G2654750
Coding: 0001175
Shop #: WSC 31414 790 00001
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 GD HW: 09D 927 750 GD
Component: AL 750 6A 1093
Revision: 00H61000 Serial number:
Coding: 0004216
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.lbl
Part No SW: 7L0 907 379 K HW: 7L0 907 379 K
Component: ESP ALLRAD MK25E1 0302
Revision: 00H53001
Coding: 0004354
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 135 B HW: 5WK 485 16
Component: Kessy 6840
Revision: 68406620 Serial number: VWX3Z0G2654750
Coding: 0000232
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 08: Auto HVAC Labels: None
Part No: 7L6 907 040 AD
Component: CLIMAtronic R/L 4326
Coding: 0020030
1 Fault Found:
00353 - Function Return Message from Fresh Air Blower Regulator
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Voltage: 14.70 V
Voltage: 11.39 V
Voltage: 13.45 V
Voltage: 14.00 V
Address 09: Cent. Elect. Labels: 7L6-937-049.lbl
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2000
Revision: -0004--- Serial number: --------------
Coding: 230002002F043C000000000000000000
4 Faults Found:
01498 - Bulb for Parking Lamps; Right (M3)
011 - Open Circuit - Intermittent
01497 - Bulb for Blinkers; Front Right (M7)
00979 - Lamp for Low Beam; Right (M31)
01499 - Bulb for High-Beams; Right (M32)
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234 3A VW8T 0250
Revision: 92011025 Serial number: 0039P002MEE3
Coding: 0013121
Part No: 7L0 959 339 E
Component: BF-Gewichtsens. 007 0009
1 Fault Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Mileage: 18 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:14
Part No: 7L6 953 549 F
Component: J527 3601
Coding: 0010011
Address 17: Instruments Labels: 7L6-920-xxx-17.lbl
Part No SW: 7L6 920 975 L HW: 7L6 920 975 L
Component: J285 KOMBI-INST. 7320
Revision: KHH05V03
Coding: 0007201
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No SW: 6N0 909 901 HW: 7L6 920 975 L
Component: J533 GW-K-CAN TP20 7320
Coding: 57E2F79B61066002
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No SW: 7L6 919 879 B HW: 7L6 919 879 B
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1439802T0HAA02
Shop #: WSC 00000 000 00000
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
Address 46: Central Conv. Labels: None
Part No: 7L6 959 933
Component: 13 HSG 7124
Coding: 0000085
Part No: 7L0 959 701 M
Component: Tuersteuergeraet FS 6301
Part No: 7L0 959 702 M
Component: Tuersteuergeraet BF 6301
Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148 )
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 56: Radio Labels: None
Part No SW: 7L6 035 180 C HW: 7L6 035 180 C
Component: Radio DE2 0008
Revision: 00005000 Serial number: VWZ4Z4GN011424
Coding: 0001400
Address 65: Tire Pressure Labels: 7L6-907-273.lbl
Part No SW: 7L6 907 273 E HW: 7L6 907 273 E
Component: J0502 RDK 0006
Revision: 00004006 Serial number: 00000900007941
Coding: 0040006B6B0000000000000000
1 Fault Found:
02214 - Tire Pressure Warning
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 18
Mileage: 19273 km
Time Indication: 0
Date: 2008.12.29
Time: 16:20:07
Freeze Frame:
(no units): 77.0
Address 68: Wiper Electr. Labels: None
Part No: 7L6 955 119
Component: J400__ Front Wiper 5101
Coding: 0000341
Part No: 1K0 955 559 AF
Component: RLS 130907 046 0204
Coding: 00208933
Shop #: WSC 31414
Address 69: Trailer Labels: Redir Fail!
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000002
Address 6D: Trunk Elect. Labels: None
Part No SW: 7L6 959 107 A HW: 7L6 959 107 A
Component: J605 HECKKLAPPE 1210
Revision: --H05--- Serial number: --------019926
Coding: 0122110
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No SW: 7L6 919 044 Q HW: 7L6 919 044 Q
Component: J702 Dachdisplay 0400
Revision: --30004S Serial number: 00000000036603
Address 76: Park Assist Labels: 3D0-919-283.lbl
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
End
My God,it's full of stars
Before posting make sure you head the post with your year, engine code etc Yes I know you can get that from the VIN but let's not make it more convoluted.
Also before attempting ANY mods, write down your original values
This is for my 2008 V8 with Air Suspension...
Sunday,04,July,2010,13:43:31:17415
VCDS Version: Release 10.6.0
Data version: 20100630
Address 01: Engine
Protocol: KWP2000
Part No: 7L0 907 560 B
Component: 4.2l V8/4V 0030
Coding: 04210009590F0560
Shop #: WSC 31414
Protocol: KWP2000
Part No: 09D 927 750 ET
Component: AL 750 6A 0994
Coding: 0004216
Shop #: WSC 31414
Protocol: CAN
Part No: 7L0 907 379 K
Coding: 0004482
Shop #: WSC 31414
Protocol: CAN
Part No: 7L0 909 137 C
Component: G2 Kessy 6850
Coding: 0147688
Shop #: WSC 07207
Protocol: CAN
Part No: 7L6 907 044 AD
Component: CLIMAtronic 2+2 4326
Coding: 0021220
Shop #: WSC 07207
Protocol: CAN
Part No: 7L6 937 049 AF
Component: J519 2001
Coding: 620008003F243C000000000000000000
Shop #: WSC 31414
Address 0F: Digital Radio
Protocol: CAN
Part No: 8E0 035 593 H
Component: SDAR SIRIUS
Shop #: WSC 00000
Address 15: Airbags
Protocol: CAN
Part No: 7L0 959 655
Coding: 0013121
Shop #: WSC 31414
Protocol: CAN
Component: Lenksaeulenmodul 3501
Coding: 0010011
Shop #: WSC 31414
Protocol: CAN
Part No: 7L6 920 985 K
Component: J0285 KOMBI-INST. 7018
Coding: 0005201
Shop #: WSC 05811
Protocol: CAN
Part No: 6N0 909 901
Component: J533 GW-K-CAN TP20 7018
Coding: 7FE2FFFB6B066002
Shop #: WSC 05811
Protocol: CAN
Part No: 7L6 919 879 B
Shop #: WSC 00000
Address 22: AWD
Protocol: KWP2000
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0119
Shop #: WSC 00000
Address 25: Immobilizer
Protocol: KWP2000
Coding: 0147688
Shop #: WSC 07207
Address 34: Level Control
Protocol: CAN
Part No: 7L0 907 553 G
Component: LUFTFDR.-CDC- 3C3P1 3112
Coding: 0015521
Shop #: WSC 31414
Address 36: Seat Mem. Drvr
Protocol: CAN
Part No: 7L0 959 760
Component: Sitzverstellung 0702
Shop #: WSC 00000
Address 37: Navigation
Protocol: CAN
Part No: 7L6 919 887 N
Component: Navigation 0022
Coding: 0000101
Shop #: WSC 31414
Protocol: KWP2000
Component: 10 HSG 7124
Coding: 0000085
Shop #: WSC 31414
Address 47: Sound System
Protocol: CAN
Part No: 7L6 035 466 A
Component: DSP 10 Kanal 0003
Shop #: WSC 00000
Address 55: Xenon Range
Protocol: CAN
Part No: 7L6 907 357 A
Component: AFS-Steuergeraet X014
Coding: 1292291
Shop #: WSC 31414
Address 56: Radio
Protocol: CAN
Part No: 7L6 035 186 F
Component: Radio 0022
Coding: 0010076
Shop #: WSC 31414
Protocol: CAN
Part No: 7L6 907 273 E
Shop #: WSC 31414
Protocol: CAN
Coding: 0000341
Shop #: WSC 31414
Address 69: Trailer
Protocol: CAN
Part No: 7L0 907 383 G
Coding: 0000002
Shop #: WSC 07207
Address 6C: Back-up Cam.
Protocol: CAN
Part No: 7L6 907 441 C
Component: J772__Rearview 0021
Coding: 0100001
Shop #: WSC 31414
Protocol: CAN
Part No: 7L6 959 107 A
Coding: 0122110
Shop #: WSC 31414
Protocol: CAN
Part No: 7L6 919 044 Q
Shop #: WSC 00000
Protocol: CAN
Shop #: WSC 00000
siberian
I am actually looking for 2 scans:
1. US spec '08 T2 V10 with all options including Rear Diff Lock (1Y1 option code)
2. US spec '08 T2 V10 with all options including Rear Diff Lock and Adaptive Cruise Control
I am also looking for a scan of '08 T2 with 3 diff locks: center, rear and front (1Y4 option code).
In the meantime, why don't you post what you have?
siberian
Here is my scan (please ignore errors):
VCDS said:
Friday,08,October,2010,22:53:48:13569
VCDS Version: Release 10.6.1
Data version: 20100831
Chassis Type: A9 - VW Touareg NAR
VIN: WVGPT77L78DXXXXXX Mileage: 72920km/45310miles
Address 01: Engine Labels: None
Part No SW: 070 906 016 DT HW: 070 906 016 DH
Component: V10 5,0L EDCG000AGMª1249
Revision: --H05--- Serial number: VWX3Z0G6613245
Coding: 0060575
VCID: 65CBCA4DD513
Readiness: 0 0 0 0 0
Part No SW: 09D 927 750 GP HW: 09D 927 750 GP
Component: AL 750 6A 1069
Coding: 0004216
VCID: 820171D1A47D
Revision: 00H53001
Coding: 0008578
VCID: 41833EDD61FB
Part No SW: 7L0 909 137 B HW: 5WK 485 17
Component: 11 Kessy 6840
Revision: 68406418 Serial number: VWX3Z0G6613245
Coding: 0147688
VCID: 32616111D45D
Part No: 4E0 905 852 E
Component: ELV 1940
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded
Address 06: Seat Mem. Pass Labels: None
Component: Sitzverstellung 0701
VCID: F7F71005FFBF
Coding: 0001030
Shop #: WSC 20130 444 57133
VCID: 76E99D0178B5
Part No: 7L6 907 049 F
Component: CLIMAtronic FOND 0503
Part No SW: 7L6 937 049 AG HW: 7L6 937 049 AG
Revision: -1004--- Serial number: --------------
Coding: 230008002F2039000000000000000000
VCID: 81037EDDA17B
Address 11: Engine II Labels: None
Component: V10 5,0L EDCG000AGSª1249
Coding: 0060575
VCID: 65CBCA4DD513
Revision: 92011025 Serial number: 0039P001DJ5W
Coding: 0013121
VCID: FAF10931CCAD
Part No: 7L0 959 339 F
Component: BF-Gewichtsens. 007 0010
Part No: 7L6 953 549 G
Coding: 0010212
VCID: 438F34D57BE7
Address 17: Instruments Labels: 7L6-920-xxx-17-7L6.lbl
Part No SW: 7L6 920 985 T HW: 7L6 920 985 T
Revision: KHH06V01
Coding: 0005211
VCID: 4E9915E1A0A5
Address 18: Aux. Heat Labels: Redir Fail!
Part No: 7L6 815 071 G
Component: Standheizung E1MAC 0425
Coding: 0000100
VCID: 36695D013835
Part No SW: 6N0 909 901 HW: 7L6 920 985 T
Coding: 7FF2FFFF6B076002
VCID: F0E52B199AD1
Revision: 00001000 Serial number: 1439802T0BDE02
VCID: 46892DC148D5
VCID: 7F077825578F
Address 34: Level Control Labels: None
Coding: 0015521
VCID: 377750053F3F
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzverstellung 0703
VCID: F7F71005FFBF
Address 37: Navigation Labels: None
Component: Navigation 0024
Coding: 0000101
VCID: 51A30E9DB19B
1 Fault Found:
02731 - CD Reading Error
Coding: 0000085
Shop #: WSC 07208 444 57852
VCID: FF07F825D78F
Part No: 7L0 959 701 P
Component: Tuersteuergeraet FS 6302
Part No: 7L0 959 702 P
Component: Tuersteuergeraet BF 6302
Part No: 7L0 959 703 D
Part No: 7L0 959 704 D
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No SW: 7L6 035 466 A HW: 7L6 035 466 A
Revision: 00001000 Serial number: 00000000003144
VCID: 32616111D45D
1 Fault Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 192
Reset counter: 214
Mileage: 71368 km
Time Indication: 0
Date: 2010.09.29
Time: 13:08:32
Address 55: Xenon Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 A HW: 7L6 907 357 A
Revision: H01 Serial number:
Coding: 1292291
VCID: 3973563D092B
Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l X008
Coding: 00000019
Component: AFS-Lst.-Modul r X008
Coding: 00000019
Address 56: Radio Labels: 7L6-035-186-DVD.lbl
Component: Radio 0024
Coding: 0010076
VCID: 36695D013835
1 Fault Found:
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Revision: 00004006 Serial number: 00000600005944
Coding: 0040009B9B0000000000000000
VCID: 3A7149310C2D
Coding: 0000341
VCID: F7F71005FFBF
Component: RLS 110607 046 0204
Coding: 00208933
Shop #: WSC 31414
Coding: 0000002
VCID: 387553393221
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 C HW: 7L6 907 441 C
Revision: 00H13000 Serial number: PA8 J750048
Coding: 0110001
VCID: 356B5A0D2533
Revision: --H05--- Serial number: --------015388
Coding: 0122110
VCID: 3973563D092B
Revision: --30004S Serial number: 00000000024401
VCID: 458B2ACD75D3
VCID: 3973563D092B
End ---------------------------------------------------------------------
2004 V8 Air ... Can someone tell me what repairs I need to make? :)
Scan: 01,02,03,05,06,08,09,15,16,17,19,1C,22,29,34,36,37,39,46,47,55,56,65,68,6E
Address 01 -------------------------------------------------------
Controller: 4D0 907 560 DA
Component: 4.2L V8/5V G 0020
Coding: 0007875
Shop #: WSC 31414
Address 02 -------------------------------------------------------
Controller: 09D 927 750 N
Component: AL 600 6Q 0565
Coding: 0004153
Shop #: WSC 02134
Address 03 -------------------------------------------------------
Controller: 7L0 907 379 C
Component: ESP ALLRAD MK25 0107
Coding: 0014593
Shop #: WSC 31414
Address 05 -------------------------------------------------------
Controller: 3D0 909 135 M
Component: Kessy 6400
Coding: 0147688
Shop #: WSC 02134
4 Faults Found:
00179 - Left Access/Start Authorization Antenna (R134)
011 - Open Circuit
00180 - Right Access/Start Authorization Antenna (R135)
011 - Open Circuit
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
00183 - Interior Access/Start Authorization Antenna 1 (R138)
011 - Open Circuit
Address 06 -------------------------------------------------------
Controller: 7L0 959 760
Coding: 0000000
Shop #: WSC 00000
3 Faults Found:
02328 - Position Sensor for Rear Seat Height Adjustment (G439)
006 - Short to Plus - Intermittent
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
01915 - Lumbar Support Height Adjustment Sensor (G374)
Address 08 -------------------------------------------------------
Controller: 7L6 907 040 AD
Coding: 0020030
Shop #: WSC 02107
1 Fault Found:
01592 - Air Quality Sensor (G238)
014 - Defective
Address 09 -------------------------------------------------------
Controller: 7L6 937 049 K
Component: 2703
Coding: 0105948
Shop #: WSC 02134
3 Faults Found:
00979 - Lamp for Low Beam: Right (M31)
010 - Open or Short to Plus - Intermittent
00907 - Intervention load Management
000 - -
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal - Intermittent
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 7L6 953 549 D
Component: Lenksäulenmodul 3301
Coding: 0000032
Shop #: WSC 31414
Address 17 -------------------------------------------------------
Controller: 7L6 920 980 M
Component: KOMBIINSTRUMENT RB8 2935
Coding: 0007131
Shop #: WSC 02134
1 Fault Found:
00464 - Control Module with Display for Radio and Navigation (J503)
004 - No Signal/Communication
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 02134
2 Faults Found:
00463 - Control Module for Digital Sound Package (J525)
Address 1C -------------------------------------------------------
Controller: 7L6 919 879
Component: JCI PathPoint 1600
Coding: 0000000
Shop #: WSC 00000
Address 22 -------------------------------------------------------
Controller: 0AD 927 755 BE
Component: TRANSFERCASE 0122
Coding: 0000000
Shop #: WSC 00000
1 Fault Found:
02039 - Position Sensor in Transfer Case (G398)
Address 29 -------------------------------------------------------
Controller: 3D0 909 157
Component: EVG GDL+AutoLWR(l) X012
Coding: 0000003
Shop #: WSC 31414
Address 34 -------------------------------------------------------
Controller: 7L6 907 553 B
Component: LUFTFDR.-CDC- 3C1P1 3650
Coding: 0015520
Shop #: WSC 31414
Address 36 -------------------------------------------------------
Coding: 0000000
Shop #: WSC 00000
2 Faults Found:
Address 39 -------------------------------------------------------
Controller: 3D0 909 158
Component: EVG GDL+AutoLWR(r) X012
Coding: 0000003
Shop #: WSC 31414
1 Fault Found:
01344 - HID (Xenon) Headlight
012 - Electrical Fault in Circuit - Intermittent
Address 46 -------------------------------------------------------
Controller: 7L0 959 933 E
Component: 2M HSG 0201
Coding: 0000085
Shop #: WSC 02134
Address 65 -------------------------------------------------------
Controller: 7L6 907 273 B
Component: Reifendruckueberw. 0053
Coding: 0110320
Shop #: WSC 00000
1 Fault Found:
01507 - Initialization Not Successful
000 - - - Intermittent
Address 68 -------------------------------------------------------
Controller: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 00000
Address 6E -------------------------------------------------------
Controller: 7L6 919 044 F
Component: DACHDISPLAY 0530
Coding: 0000000
Shop #: WSC 02134
I agree, I should clear the codes and see what comes back.
The radio faults are because I have an aftermarket system.
These appear to be seat faults but not sure why there would be a position sensor for rear seat height adjustment..
Coding: 0000000
Shop #: WSC 00000
2 Faults Found:
I am not sure about these...
Coding: 0147688
Shop #: WSC 02134
4 Faults Found:
011 - Open Circuit
011 - Open Circuit
011 - Open Circuit
011 - Open Circuit
Coding: 0000000
Shop #: WSC 00000
1 Fault Found:
Coding: 0110320
Shop #: WSC 00000
1 Fault Found:
What does the air quality sensor even check?
Coding: 0020030
Shop #: WSC 02107
1 Fault Found:
014 - Defective
Last I have been having issues with my headlight output. I think some of these faults might be because I ran the car without the headlight assembly installed, but I still suspect there might be a real short.
Coding: 0000003
Shop #: WSC 31414
1 Fault Found:
Component: 2703
Coding: 0105948
Shop #: WSC 02134
3 Faults Found:
000 - -
The vehicle I just purchased is the first one you list. I don't have a VCDS, but I am thinking about buying it now that I have two VW / Audi cars in the garage.
Maybe there is someone in the San Francisco Bay Area that would be willing to scan my car and post the results here? Just let me know. . .
Old Scan - I'll go pull one tonight or tomorrow. After I did this scan, I recoded my instruments to ROW - I've never looked to see if that changes anything on the scan.....
08 FSI V6
VCDS Version: Release 908.2
Data version: 20100326
Friday,23,April,2010,16:00:26:30512
VIN: WVGLE77L58Dxxxxxx Mileage: 45590km/28328miles
Part No SW: 03H 906 032 CB HW: 03H 906 032 S
Component: T-GP LEV2 G 1667
Coding: 0011175
Coding: 0004216
Part No SW: 7L0 907 379 L HW: 7L0 907 379 L
Component: ESP ALLRAD MK25E1 0303
Revision: 00H53001
Coding: 0004482
Coding: 0147688
Component: ELV XXXX
Part No: 7L6 907 044 AF
Component: CLIMAtronic 2+2 4331
Coding: 0020030
Coding: 220008002F243C000000000000000000
Coding: 0013121
Coding: 0010011
Part No SW: 7L6 920 990 HW: 7L6 920 990
Component: J285 KOMBI-INST. 7520
Revision: KHH06V02
Coding: 0007201
Shop #: WSC 26002 444 58643
Part No SW: 6N0 909 901 HW: 7L6 920 990
Component: J533 GW-K-CAN TP20 7520
Coding: 7FE2F7FB6B046002
Part No: 7L0 907 553 J
Component: LUFTFDR.-CDC- 3C3P1 3125
Coding: 0015521
Component: Navigation 0029
Coding: 0000101
Part No: 7L6 959 933 A
Component: 19 HSG 0600
Coding: 0000085
Revision: 00001000 Serial number: 00000000005935
Component: AFS-Steuergeraet 0001
Revision: H02 Serial number:
Coding: 1292419
Coding: 00000019
Coding: 00000019
Component: Radio 0029
Coding: 0010076
Revision: 00004006 Serial number: 00000700009244
Coding: 0040008D8D0000000000000000
Part No: 7L6 955 119 B
Component: J400__ Front Wiper 5301
Coding: 0001397
Component: RLS 101207 046 0204
Coding: 00208933
Shop #: WSC 31414
Part No SW: 7L0 907 383 L HW: 7L0 907 383 L
Component: J345 Anhaenger 0080
Revision: 4A014001 Serial number: 00000108074651
Coding: 0002050
Address 6C: Back-up Cam. Labels: 5N0-907-441.lbl
Revision: 00H13000 Serial number: PA8 J7Z0008
Coding: 0110001
Revision: --H05--- Serial number: --------025527
Coding: 0122110
Revision: --30004S Serial number: 00000000050924
Updated Scan... from 10/31.
The coding of my instruments is different, reflecting the ROW coding.
Sunday,31,October,2010,14:03:50:30512
VIN: WVGLE77L58Dxxxxxx Mileage: 60140km/37369miles
Coding: 0011175
VCID: 64CC2B1ADE29
Coding: 0004216
VCID: 76E8615278B5
Revision: 00H53001
Coding: 0004482
VCID: 4280CD8264FD
Coding: 0147688
VCID: 32609D42D45D
Component: ELV XXXX
Coding: 0020030
VCID: 78F46F6A72A1
VCID: 8004878AAA71
Revision: 92011025 Serial number: 0039P003JX9F
Coding: 0013121
VCID: FAF0F562CCAD
Coding: 0010011
VCID: 4280CD8264FD
Revision: KHH06V02
Coding: 0007101
VCID: F6E8E152F8B5
VCID: F0E4D74A9AD1
VCID: 8102828EA17B
Coding: 0015521
VCID: 3A70B5620C2D
Coding: 0000101
VCID: 51A2F2CEB19B
Coding: 0000085
VCID: 4084C78A6AF1
VCID: 32609D42D45D
Coding: 1292419
VCID: 3972AA6E092B
Coding: 00000019
Coding: 00000019
Coding: 0010076
VCID: 3668A1523835
VCID: 3A70B5620C2D
Coding: 0001397
VCID: 3972AA6E092B
Coding: 00208933
Shop #: WSC 31414
Coding: 0002050
VCID: 3D7ABE7E1D03
Coding: 0110001
VCID: 356AA65E2533
Coding: 0122110
VCID: 3972AA6E092B
VCID: 458AD69E75D3
VCID: 3972AA6E092B
Here is a scan of our 2011 V6 TDI Execline (CANADA)
Hope someone can help with this, as the longcoding helper does not seem to have any info on any of these modules.
Tuesday,16,November,2010,13:24:31:18045
Chassis Type: 7P6
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
62 65 69 6C 6D 72
VIN: WVGDK9BP4BD00xxxx
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
47-Sound System -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (J623-CATA) Labels: None
Part No SW: 7P0 907 401 E HW: 7P0 907 401 E
Component: 3.0TDI EDC17 H17 0005
Revision: 56H17---
Coding: 292A4012233600050000
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_ECM30TDI0117P0907401E 001007
ROD: EV_ECM30TDI0117P0907401E.rod
VCID: 3162C5B4D15B
Address 02: Auto Trans (J217) Labels: None
Part No SW: 0C8 927 750 G HW: 0C8 927 750 G
Component: AL1000 AISIN 001 1812
Serial number:
Coding: 001368
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_VW52.rod
VCID: 3064C0B0DA51
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 7P0 907 379 E HW: 7P0 907 379 A
Component: MK25A H33 0416
Revision: -------- Serial number: 423400010EC010
Coding: 5B7613C349242554DAFDC89992D4A4407700
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_MK25AXT.rod
VCID: 3F86938C170F
Address 05: Acc/Start Auth. (J393) Labels: None
Part No SW: 4H0 907 064 AK HW: 4H0 907 064 AK
Component: BCM2 2.0 H23 0208
Revision: 00002001
Coding: 0D860000000000000000
VCID: 72E00AB814DD
Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 7P6 907 040 AG HW: 7P6 907 040 AG
Component: Klima 2 Zonen H18 0612
Coding: B686000A80
VCID: 79F23D9449AB
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 4H0 907 063 D HW: 4H0 907 063 D
Component: BCM1 2.0 H11 0083
Revision: 15011002 Serial number: 00000000624366
Coding: 26001012D73C5D010020180380005D0C431C660882010261800000020000
VCID: 29522DD4F98B
Part No SW: 7P0 955 119 HW: 7P0 955 119
Component: WWS 100725 31 0020
Coding: 004DBD
Part No SW: 7P0 955 559 D HW: 7P0 955 559 D
Component: RLFS H09 0011
Coding: 035223
Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Part No SW: 002 0 HW: 31
90243400100804172639 7P0955119
Coding: 3750303935353131392020
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 7P6 919 475 HW: 7P6 919 475
Component: PARKHILFE 8K H03 0016
Revision: -------- Serial number: 38941022102878
Coding: 318501
ASAM Dataset: EV_VW526ParkiAssis2 001008
ROD: EV_VW526ParkiAssis2.rod
VCID: 55AA51248573
Address 15: Airbags (J234) Labels: None
Part No SW: 7P0 959 655 A HW: 7P0 959 655 A
Component: VW10Airbag095 H05 0020
Revision: -------- Serial number: 003FH0010JX2
Coding: 000000000000000000000000000000003935
ASAM Dataset: EV_AirbaVW10BPAVW526 001001
ROD: EV_AirbaVW10BPAVW526.rod
VCID: 3F86938C170F
Seat occupied recognition:
Part No SW: 7P6 959 339 HW: 7P6 959 339
Serial number: 5850000R1070300JN9
Driver's Airbag Crash Sensor:
Serial number: 3575LRB406300TMO7GAS
Passenger Side Airbag Crash Sensor:
Serial number: 3585LRB405F6UFCK71UA
Driver's Rear Airbag Crash Sensor:
Serial number: 3515RRB405L6T8MG894$
Passenger's Rear Airbag Crash Sensor:
Serial number: 3525RRB405L6T8MG687/
Driver's Front Airbag Crash Sensor:
Serial number: 3555NRB405V6THNEIOPH
Passenger's Front Airbag Crash Sensor:
Serial number: 3565NRB405P6THNE5GS.
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4H0 953 568 B HW: 7P6 953 507 A
Component: Lenks.Modul H07 0007
Revision: -------- Serial number: 90815JHP0000N
Coding: 000C15
VCID: 3260CAB8D45D
Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Address 17: Instruments (J285) Labels: None
Part No SW: 7P6 920 880 A HW: 7P6 920 880 A
Component: Kombi H09 0114
Revision: 08240053 Serial number: 658300810593031
Coding: 0B3731002B000008000004
ASAM Dataset: EV_KombiUDSRBVW526 001011
ROD: EV_KombiUDSRBVW526.rod
VCID: 3972FD94092B
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000033937
Coding: 0001037500
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewVW526UDS.rod
VCID: 3874F8903221
Control unit for battery monitoring:
Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650351662
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00001002082619
Coding: 00581B0000004001000001010101202020202121202020
VCID: 346CCCA02E49
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000107472397
Coding: 011D17205E00453005080000
VCID: 3C7CE4800619
Address 46: Central Conv. (J393) Labels: None
Revision: 00002001 Serial number: 0132613691
Coding: 0106123A28B9509580A00620210000000000000000000000000000000000
VCID: 72E00AB814DD
Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Part No: 1K0 951 605 C
Part No SW: 7P0 959 591 HW: 7P0 959 591
Component: J245 PS30.050 H05 0006
Coding: 191100
Part No SW: 7P0 959 591 A HW: 4H0 959 591
Component: J394 PS30.050 H06 0006
Coding: 191100
Address 47: Sound System (J525) Labels: None
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10810000508505
VCID: F5EAB1A4E5B3
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000107318778
VCID: 3B7EE79C0317
Address 53: Parking Brake (J540-) Labels: None
Part No SW: 7P0 907 801 E HW: 7P0 907 801 E
Component: EPB H51 1100
Revision: 00000000 Serial number: A1062700228
Coding: 01040000
ROD: EV_ParkbA7.rod
VCID: 356AF1A42533
Address 55: Xenon Range (J745) Labels: None
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: --------------
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS.rod
VCID: FCFCA480C699
Address 56: Radio (R) Labels: None
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471HU0A7523206
Coding: 020007010000000001
VCID: DDBAC9047D43
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 7P6 035 664 HW: 7P6 035 664
Component: H-BN-NA H43 0170
Revision: -------- Serial number: 445H%0A7505865
Coding: 020200050040E1EF41022B0E00000003F0000101
VCID: F5EAB1A4E5B3
Part No: 8R0 060 884 P
Component: NAR 2010 0407
Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H23 0045
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000107445305
Coding: 011C17200000253005080000
VCID: 3A70E2980C2D
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000009234
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25.rod
VCID: 3F86938C170F
Address 69: Trailer (J345) Labels: None
Part No SW: 7P0 907 383 B HW: 7P0 907 383 B
Component: Anhaenger H07 0100
Revision: 5A001002 Serial number: 00000133837075
Coding: 020D000000000000
VCID: 3776FBAC3F3F
Address 6C: Back-up Cam. Labels: None
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H03000 Serial number: 525 PA8J080184
Coding: 0130001
VCID: 3776FBAC3F3F
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 09145444 Serial number: 233000126
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
VCID: FCFCA480C699
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000107402196
VCID: 3A70E2980C2D
Okay, I already did some Vag-Com mods before I saw this but here is my output scan...
2010 Volkswagen Touareg V6 TDI
ECU #EDC17G000AG-0050
Part # 7L0-907-401-T
Wednesday,15,December,2010,14:43:23:41320
VCDS Version: Release 10.6.3
Data version: 20101206
VIN: WVGFK7A97AD003428 Mileage: 5310km/3299miles
Address 01: Engine (CAT) Labels: 059-907-401-CAT.clb
Part No SW: 7L0 907 401 T HW: 7L0 907 401 K
Component: 3.0TDI EDC17G004AG 0050
Coding: 0421002A590F0968
VCID: 3C7DC46D06ED
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Part No SW: 09D 927 750 LD HW: 09D 927 750 LD
Component: AL 750 6A 1667
Revision: 00H89000 Serial number:
Coding: 0013176
VCID: 7BFF07714363
Part No SW: 7L0 907 379 P HW: 7L0 614 517 C
Component: ESP ALLRAD MK25E1 0304
Revision: 00H53001
Coding: 0004354
VCID: 4689A6854821
Part No SW: 7L0 909 135 C HW: 7L0 909 135 C
Component: Kessy 6850
Revision: 00H22072 Serial number: VWX3Z0J2909032
Coding: 0000232
VCID: 3163E559D1AF
Component: ELV XXXX
Part No: 7L6 907 040 AL
Component: CLIMAtronic R/L 4537
Coding: 0023030
VCID: 7AF102754C59
Component: J519 2004
Coding: E00002002F00BC000000000000000000
Shop #: WSC 26085 444 84534
VCID: 8005F09DAA85
Part No SW: 7L0 959 655 A HW: 7L0 959 655 A
Component: J234__0D VW8T 0270
Revision: 92013027 Serial number: 003C6001CWG$
Coding: 0012356
VCID: 3B7FC77103E3
Coding: 0010011
VCID: 4281BA956409
Address 17: Instruments Labels: None
Part No SW: 7L6 920 972 A HW: 7L6 920 972 A
Component: J285 KOMBI-INST. 9833
Revision: KHH05V46
Coding: 0005101
VCID: 3777DB413FCB
Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 972 A
Component: J533 GW-K-CAN TP20 9833
Coding: 57E2F79BE1066002
VCID: F0E5A05D9A25
Revision: 00001000 Serial number: 1439802T1GYV02
VCID: 4689A6854821
VCID: 8103F599A18F
Component: 4M HSG 0601
Coding: 0000085
VCID: 4085B09D6A05
Component: Tuersteuergeraet FS 6304
Component: Tuersteuergeraet BF 6304
Revision: 00007000 Serial number: VWZ4Z4K7329043
Coding: 0003400
VCID: 2D5BF929CD97
Revision: 00004006 Serial number: 00000700016189
Coding: 0440008D8D0000000000000000
VCID: 3A71C2750CD9
Coding: 0001397
VCID: 3973DD7909DF
Part No: 1K0 955 559 AH
Component: RLS 290110 054 0403
Coding: 00208941
Shop #: WSC 31414
Part No SW: 7L0 907 383 N HW: 7L0 907 383 N
Revision: 4A009002 Serial number: 00000128910679
Coding: 0016386
Shop #: WSC 00512 001 24584
VCID: 3F87B36117FB
Part No SW: 7L6 959 107 B HW: 7L6 959 107 B
Component: J605 HECKKLAPPE 1310
Revision: --H05--- Serial number: --------051028
Coding: 0122110
VCID: 3A71C2750CD9
Part No SW: 7L6 919 044 AD HW: 7L6 919 044 AD
Component: J702 Dachdisplay 0401
Revision: 1030006S Serial number: 00000000151097
VCID: 79F31D79495F
Component: 0L Einparkhilfe 1108
VCID: 3973DD7909DF
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 E HW: 1Z0 035 729 E
Component: FSE_2P8x H40 0190
Revision: 00000000 Serial number: 00000005183782
Coding: 0002077
VCID: 3A71C2750CD9
2011 Execline TDI scan
Sorry, duplicate post deleted.
Monday,02,May,2011,18:51:27:04442
VCDS Version: Release 10.6.4
Data version: 20110418
VIN: WVGZZZ7LZ8D046567 Mileage: 86780km/53922miles
Address 01: Engine (CAS) Labels: None
Part No SW: 7L0 907 401 N HW: 7L0 907 401 H
Component: 3.0TDI EDC17G100AG 0060
Revision: --H02--- Serial number: VWX3Z0G1687973
Coding: 04210023590F0568
Shop #: WSC 30049 959 91392
VCID: 3669369338D7
Part No SW: 09D 927 750 FT HW: 09D 927 750 FT
Component: AL 750 6A 1168
Revision: 00H75000 Serial number:
Coding: 0004456
VCID: 850B015FB5B1
1 Fault Found:
01314 - Engine Control Module
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 24
Mileage: 0 km
Time Indication: 0
Revision: 00H53001
Coding: 0004482
VCID: 42815A43641F
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 85639 km
Time Indication: 0
Date: 2011.04.20
Time: 14:44:59
Freeze Frame:
Count: 0
Count: 4097
Count: 8194
Count: 3
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 B HW: 5WK 485 04
Revision: 68406620 Serial number: VWX3Z0G1687973
Coding: 0000232
VCID: 2855E8EBE263
Component: ELV XXXX
Coding: 0020020
VCID: 78F5F8AB7243
Coding: 400004002B221C000000000000000000
VCID: 8005104BAA93
Component: J234 39 VW8T 0250
Revision: 92011025 Serial number: 0039P003JRFF
Coding: 0013113
VCID: FAF162A3CC4F
1 Fault Found:
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Mileage: 51489 km
Time Indication: 0
Date: 2010.05.17
Time: 15:08:28
Freeze Frame:
Ign. Timing: -0.0 �ATDC
Raw, Form. N/A: 000 000 006
Raw, Index/Key Err.: 251 184 134
Misfires: 134.6/s
Mass Flow: -109.23 g/s
(no units): 71.0
Turn Rate: -238.5�/s
Fuel Consump.: 435.5 l/100km
Coding: 0010011
VCID: 42815A43641F
Part No SW: 7L6 920 885 R HW: 7L6 920 885 R
Revision: KHH06V02
Coding: 0007101
Shop #: WSC 20072 067 57207
VCID: 4B9F77675355
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 85639 km
Time Indication: 0
Date: 2011.04.20
Time: 14:44:59
Part No SW: 6N0 909 901 HW: 7L6 920 885 R
Coding: 7FE2E7A9C8046003
VCID: F0E5408B9A33
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 85639 km
Time Indication: 0
Date: 2011.04.20
Time: 14:44:59
VCID: 8103154FA199
Coding: 0015521
VCID: 3A7122A30CCF
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 7L6 035 680 C HW: 7L6 035 680 A
Component: RNS-MID H04 2682
Revision: AB001001 Serial number: VWZ6Z7G7272099
Coding: 000004000000002000
ASAM Dataset: ------------------------- ------
VCID: 32610A83D4BF
2 Faults Found:
01044 - Control Module Incorrectly Coded
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 254
Reset counter: 232
Time Indication: 0
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 192
Mileage: 86784 km
Time Indication: 0
Date: 2011.05.02
Time: 17:19:31
Component: 1A HSG 0600
Coding: 0000081
VCID: 4085504B6A13
Part No: 7L0 959 701 R
Part No: 7L0 959 702 R
Part No: 7L6 959 703
Component: Tuersteuergeraet HL 0202
Part No: 7L6 959 704
Component: Tuersteuergeraet HR 0202
Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Part No: 7L6 951 171 B
Component: Innenraumsensor 0020
Coding: 1288579
VCID: 39733DAF09C9
Coding: 00000019
Coding: 00000019
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 218
Mileage: 85639 km
Time Indication: 0
Date: 2011.04.20
Time: 14:44:59
Freeze Frame:
Voltage: 12.07 V
Speed: 0.0 km/h
ABS 1
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 32610A83D4BF
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 232
Time Indication: 0
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 192
Mileage: 86784 km
Time Indication: 0
Date: 2011.05.02
Time: 17:19:31
Part No: 7L6 955 119 C
Coding: 0001397
VCID: 3A7122A30CCF
Component: RLS 271107 046 0204
Coding: 00208933
Shop #: WSC 31414
VCID: 39733DAF09C9
Reactions: vikobia
Chassityp: 7L - VW Touareg 03>10
Skanna: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
VIN:...... Mätarställning: 117490km
Adress 01: Motor Labels: 022-906-032-BMX.lbl
Artikelnr SW: 022 906 032 BE HW:
Komponent: MOTRONIC ME7.1.1G 0008
Kodning: 0000133
Verkstad #: WSC 00091 264 02665
VCID: 4FA8D6D9DDC60DB
6 Funna fel:
16825 - Tankurluftningssystem
P0441 - 002 - felaktigt flöde - Fellampa(MIL) tänd
18033 - Databussdrivning
P1625 - 008 - orimligt meddelande från växellådans styrdon - Intermittent fel
17924 - Ventil för omställbart insugningsrör (N156)
P1516 - 004 - avbrott - Intermittent fel
18104 - Databussdrivning
P1696 - 002 - orimligt meddelande från rattaxelelektroniken - Intermittent fel
18014 - Info om dålig väg/motorbörmoment från ABS-styrdonet
P1606 - 001 - elfel i strömkretsen - Intermittent fel
18091 - Databussdrivning
P1683 - 008 - orimligt meddelande från airbag-styrdon - Intermittent fel
Adress 02: Automatväxel Labels: 09D-927-750.lbl
Artikelnr: 09D 927 750 A
Komponent: AL 600 6Q 0360
Kodning: 0004136
VCID: 2C52A1558C10163
1 fel funnet:
01045 - Kontakt för Tiptronic (F189)
008 - Orimlig signal - Intermittent fel - Fellampa(MIL) tänd
Adress 03: Bromselektronik Labels: 7L0-907-379-MK25.lbl
Artikelnr: 7L0 907 379 A
Komponent: ESP ALLRAD MK25 0105
Kodning: 0014337
Verkstad #: WSC 01000 551 00000
VCID: 37788E394556A5B
1 fel funnet:
00778 - Givare för styrvinkel (G85)
000 - - - Intermittent fel
Adress 05: Behör.kontroll Labels: 3D0-909-13x-05.lbl
Artikelnr SW: 3D0 909 131 T HW: 5WK 470 21
Komponent: Kessy 6120
Kodning: 0000232
Verkstad #: WSC 31414 000 00000
VCID: 326EBF2DAE34403
Artikelnr: XXXXXXXXXXX
Komponent: ELV XXXX
2 Funna fel:
01299 - Diagnosinterface för databuss (J533)
005 - Ingen eller felatig grundinställning/anpassning - Intermittent fel
00668 - Spänning klämma 30
009 - Avbrott eller kortsluten till jord - Intermittent fel
Adress 08: Klimatanläggning Labels: AER\7L6-907-040.clb
Artikelnr: 7L6 907 040 D
Komponent: CLIMAtronic R/L 0302
Kodning: 0001020
VCID: 316CB021AB327BB
4 Funna fel:
02100 - Ställmotor för golvspjäll (V261)
000 - -
00657 - Ställmotor för mittre munstycken (V102)
000 - -
002 - Undre gräns överskriden - Intermittent fel
013 - Kontrollera DTC-minne - Intermittent fel
Adress 09: Elektron. elcentral Labels: AER\7Lx-937-049-V1.clb
Artikelnr: 7L6 937 049 D
Komponent: 2401
Kodning: 0100476
VCID: 3D749C11676A8FB
3 Funna fel:
00907 - Ingrepp lastmanagement
01846 - Försörjning sensor för regn-och ljuslokalisering
007 - kortsl. till jord - Intermittent fel
01520 - Sensor för regn-och ljuslokalisering (G397)
Adress 15: Krockkuddar Labels: 3D0-909-601.lbl
Artikelnr: 3D0 909 601 B
Komponent: 4 Airbag 8.4E+ H07 0641
Kodning: 0008244
Verkstad #: WSC 00000 000 00000
VCID: 224E4F6DFED4D03
1 fel funnet:
00588 - Tändare för airbag: förarsidan (N95)
001 - Övre gräns överskriden - Intermittent fel - Fellampa(MIL) tänd
Adress 16: Rattelektronik Labels: 7L6-953-549.lbl
Artikelnr: 7L6 953 549 B
Komponent: Lenksäulenmodul 3201
Kodning: 0000011
VCID: 3E769B1D6A6C943
Ingen felkod funnen.
Adress 17: Instrument Labels: 7L6-920-xxx-7LA.lbl
Artikelnr: 7L6 920 880
Komponent: KOMBIINSTRUMENT RB4 2601
Kodning: 0007111
Verkstad #: WSC 40202 222 88350
VCID: F4E2F93594A08E3
Adress 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Artikelnr: 6N0 909 901
Komponent: Gateway K<>CAN 0101
Kodning: 0000006
VCID: F0EAF525E0B8B23
Adress 22: AWD Labels: saknas
Artikelnr: 0AD 927 755 BE
Komponent: TRANSFERCASE 0122
VCID: 7F08A6192DE65DB
Adress 37: Navigering Labels: 7L6-919-887-CD.lbl
Artikelnr: 7L6 919 887
Komponent: Navigation 0629
Kodning: 0000004
VCID: 03002AE9410E39B
Adress 46: Komfortcentral Labels: 7L0-959-933.lbl
Artikelnr: 7L0 959 933 C
Komponent: 4L HSG 3214
Kodning: 0000065
VCID: 3C7291157C70863
Artikelnr: 7L0 959 701
Komponent: Tuersteuergeraet FS 0101
Artikelnr: 7L0 959 702
Komponent: Tuersteuergeraet BF 0101
Artikelnr: 7L0 959 703
Komponent: Tuersteuergeraet HL 0101
Artikelnr: 7L0 959 704
Komponent: Tuersteuergeraet HR 0101
Artikelnr: 7L0 907 719
Komponent: Neigungssensor 0018
Artikelnr: 7L6 951 171
Komponent: A Innenraumsensor 0019
7 Funna fel:
00928 - Låsenhet för centrallås förarsidan (F220)
00929 - Låsenhet för centrallås pass.sidan (F221)
00930 - Låsenhet för centrallås vänster bak (F222)
00108 - Signal centrallås SAVE/LOCK: höger bak
00931 - Låsenhet för centrallås höger bak (F223)
00323 - Givare för fordonsvinkel (G384)
014 - felaktig
Adress 56: Radio Labels: 7L6-035-186-CD.lbl
Artikelnr: 7L6 035 186 A
Komponent: Radio 0629
Kodning: 0005445
Adress 68: Torkarelekronik Labels: saknas
Artikelnr: 7L0 955 119 F
Komponent: Front Wiper 2416
Kodning: 0000003
Verkstad #: WSC 31414 000 376832
Slut --------------------------------------------------------------------
1 - 20 of 20 Posts
