Well folks, I still have my 05 V8. I'm still having problems with my actuator pod. I've gone through 2 pods already. My latest adhesive I used was JB Weld. The metal kept on coming off from the rubber pod. The actuator arm movement seems to be consistent with the upper arm. I feel like I should bore the hole of the lower arm. Maybe someone can chime in also about proper installation of the arm after disassembling it from intake. I may have messed up the installation. What position should the flaps be after disassembly. Thanks in advance.
