1 - 7 of 7 Posts
Thanks, Would you know where the front and back pressures sensors are located under the car?
G291 level control pressure sensor right side of vehicle (passenger side) under vehicle under underbody plastic trim.
It's part of the valveblock.
I just helped my dad sort his.
I stripped the pump, cleaned the bore and piston ring. Reassembled and the error hasn't returned.
It throws an error when the pressure buildup is not fast enough.
Is the valve block you refer to, the piece that has the six air line connections?
I also measured the ride height( top of wheel arch to center of axle) at each wheel and got the following:
RF= 18 5/8"
LF = 18 3/4"
RR= 20"
LR= 20 1/4"
In a calibration discussion on this forum it indicated that the nominal measurement was 400 mm or 16". If this is true for my vehicle(2005 Toruareg 4.2 v8) then the rear is very high?? and the front is higher than normal and certainly not level.
1 - 7 of 7 Posts
