1 - 7 of 7 Posts
Has anyone had the P245B code but the check engine light isn’t on? The dealership reset this code twice already but it keeps coming back. It’s actually one of those permanent codes you can’t reset yourself. Should I wait or get it fixed now? I was thinking I have warranty until 2022 so if they have to replace the valve to later the better. Thanks.
Warranty item. Dealer. Do it asap. Often times codes and problems mask other codes and problems. Don't wait.
Reactions: tdashmike
The EGR cooler assembly was replaced. They said the valve was working but the cooler was gunked up. $2100 including labor, it will be cheaper if you have an Audi or VW I would think. The part costs 3x as much for the Porsche.
That's a good question. It should have been covered by warranty and at first I had assumed that was the case but now that I relook at that message I'm wondering the same
1 - 7 of 7 Posts
