Hi Guys,
2011 VW Touareg TDI
I installed those brackets on both sides but still get that error every other week. I noticed the error triggers when I turn ignition on but doesn't start the engine yet. Like I mentioned, could drive couple of weeks without it. Battery is pretty new.
My next step:
Since p2015 is for bank1, want to swap both motors and see if this error comes for the same side or travels to another side with that motor.
If anyone knows what else could it be, please let me know. Thank you for help in advance!
P201500: Intake Manifold Runner Position Sensor/Switch Circuit, Range/Performance Status: Test failed, Pending, Test failed since last DTC clear, Test not completed during this operation cycle
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 255
Odometer: 276659 km
Date, time: 2025.04.12 17:22:09
Engine RPM: 0 rpm
Calculated engine load value: 0.00 %
Vehicle speed: 0 mph
Engine coolant temperature: 186.8 °F
Engine oil temperature: 82.4 °F
Barometric pressure: 100 kPa
Klemme 30 voltage: 12
Paramteric values: 20 96 28 10 26 00 00 11 D3 20 00 11 D1 01 C1 12 OD FC BF 12 16 37 00 42 1E 12 05 45 4D
2011 VW Touareg TDI
My next step:
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 276659 km
Engine RPM: 0 rpm
