2011 Touareg 3.6 VR6 (US):
Hi all, I’m having intermittent overheating issues with my Touareg. After I bought the car, it would start overheating on the highway after about 15 minutes of driving. I would then pull over and idle for a minute or so, causing the temperature to go back to 200°. This would happen once per drive cycle.
This led to me replacing the water pump, thermostat, and vacuum solenoid valve (for the water pump). I replaced coolant using a pressurizer so there should be no air pockets in the system. Now when I drive it uphill it will start overheating slightly and go up to 210° and even 220°. Once I am over the hill it will go back to 200°. I’m also noticing that the hose coming off the thermostat is cool which implies the thermostat isn’t opening.
What could be causing it to overheat?
