Two T's said:
Can any one tell me what type of oil the factory uses @ build, and what the recommendation is for replacement @ the 5k point.
SPB
Synthetic. It's rumored that the factory fill has certain additives for the break-in period. The specifications are in the owners manual and if different from what I have posted here you should follow those recomendations.
From the maintenance manual -
V6:
Oil system capacity:
With oil filter 6.3 ltr.
Engine oil specifications:
Use "long life engine oils" in compliance with VW standard
503 01 .
Note:
- The engine is filled at the factory with engine oil complying to VW standard 503 01 .
- Engine oils complying to VW standards 502 00 and
505 01 may continue to be used. The oils must be
changed every 12 months or every 15,000 km.
- Engine oil "ILSAC GF3 with viscosity rating SAE 5W-
40" may be used to change or top off oil.
30" may be used to change or top off oil.
V8:
Long-life engine oil
New VW standard (specifically developed, aging
resistant)
Initial filling: VW standard 503 00 (VW TL 52
173)
Note:
conforming to VW standard 503 00. This oil is
designed for long service intervals
- Engine oils conforming to VW standard 500 00,
501 01 or 502 00 can be used afterward. These
oils must be changed every 12 months or
15,000 kilometers. The service interval display
must be programmed accordingly.
V10: - my manual doesn't have this info.
