1 - 9 of 9 Posts
I am used to having trans temp gauges. Why do we have an oil temp gauge? I cant see the use for it...I could see more use out of an oil pressure gauge. I just changed the oil and now that outside temps are 100+, the oil temp is around 200*
Whats the normal operating range? I'm used to seeing it right around 175-180*
TIA
Should the oil temp gauge move at all when going up amountain I notice it normally sits at 180-200 but going up hill for about 20 miles it moves up to about 220
Looks "normal " to me.
Learner
Oil temp around 90-110 C is normal, will move with speed/ load etc.
Water should be at 90 C all the time
We live near a steep mountain area. We don't work the Touareg too hard until the oil temp is normal zone.
I would rather have a transmission temperature gauge for towing...
I have seen up to 120 celsius oil temp when towing with my R5.
Yep as said above and most important .... depends on load and time ie how long the work was done for.
I have also seen almost up to 120c in soft / hard sustained sand driving for around 50 - 100 kms and carrying around 300kgs on board as well as 2 people.
Interesting to note oil temp comes down real quick after a short stop.
And the coolant temp always was on 90c
Now i have a winch installed so for some reason it creeps up to around 108c max once normally warmed up. I still dont know how this happens considering the cooling system works through osmosis .... there is marginal blocking of the radiators .... but its not your usual sized winch
Thanks for all your answers they helped a lot I was getting worried alittle seeing the gauge move on me I'm a new owner and bought used and dropped a lot of money fixing some things and did not want to think something else was happening I love this car
1 - 9 of 9 Posts
About this Discussion
8 Participants
Ron m
Club Touareg Forum
Full Forum Listing
