2007 v6 3.6 gas 141,000 kms. Recently joined the list of the MFI "Low Oil Pressure" Club. As suggested by members of this forum, immediately changed the oil pressure sensor but problem remained. Hooked up manual gauge and cold start pressure showed 4.5 bar but dropped to 2-2.5bar within a minute of running and doesn't rise much beyond that at 2000 rpm. Did an oil change with Castro 5w-40 just as an option as well.
I've done a lot of reading but most info is quite old and was hoping to get some fresh input before I go ripping and tearing. Next step seems to be to replace the oil pump as some others have done.(for some this works and others it hasn't) but oil pumps are a pretty robust item and would be my least suspect???? There is also a mention of a check pressure valve in the oil pump /oil filter flow line path that regulates pressure??? Any idea on this and is it easy to change?
There is a lot of info on the Passat V6 world where around the 06-07 years an inferior bolt that holds a cog in the oil drive/timing chain area either sheared or backed out and either destroying or making oil pump sloppy. There is no mention of this in the Touareg Forum. Are these the same engines?????
My Touareg is a bit sluggish on initial acceleration but I assumed that is due to a 6 cylinder pushing such a heavy vehicle. The engine runs very quiet and if it weren't for the MFI warning I would not know there was a problem.
Any advice would be greatly appreciated.
