1 - 14 of 14 Posts
Hey guys,
So my 2012 CATA 3.0L TDI Highline. I replaced my oil level sensor after it **** the bed, I still get a yellow oil warning to add 1L even though my dipstick shows the oil level is fine and VCDS is getting a reading of 95mm cold from the oil level sensor.
Just curious if I have to program the new sensor to get this to work or what's the deal? No errors in VCDS.
'14 TDI Execline
Did your replacement match what you took out? Was it OEM? I don't think your CATA came stock with a dipstick, so someone must've added it. Have you validated the oil level with the VAG specific measuring tool and manual specs?
It does not come with a dipstick I bought one based on a post in this site and it works perfectly. It did match but it was not OEM. VCDS shows a reading from it, I did the oil change myself exactly as I have done for the last 3 years and with the dipstick it reads perfectly full, and previous to this malfunction it would always read full or just below based on temp / level etc....
'14 TDI Execline
I also don't know what MVBs you're looking at, so I just randomly looked at some of mine but I'm not familiar with their exact correlation to what the RNS850 displays as I've never attempted to compare them before.
Code:
Address 01: Engine  (7P0 907 401 K)
13:52:15
  IDE00151   Oil fill level 76.768 mm
  IDE00152   Oil warning threshold 39.684 mm
  IDE00196   Engine oil temperature 82.1 �C
  IDE00699   ESI: minimum oil level in service interval 11.364 mm
  IDE00700   ESI: maximum oil level in service interval 20.252 mm
  IDE06386   Oil level: static measurement 16.896 mm
  IDE06393   Oil level: dynamic average value 131.068 mm
Car Radio Gear shift Satellite radio Vehicle
Discussion Starter · #9 ·
Sorry for the late reply busy working crazy hours.
So my auto scan does not show an issue with the oil level sensor. I do have the RNS850, I have the orange oil lamp that is solid on my cluster. Under Car > Service instead of the oil fill level like yours (mine was the same when working) it just says please add max 1L of oil, you can continue driving. This does not change ever, drive for an hour or 2mins stop the car running or just acc.
I got my values from advance values in the engine module. The oil level value does change based on engine temperature, speed, sit / idle time etc.. So it seems to be working but for some reason I have that pop-up.
Discussion Starter · #10 ·
059 115 611 aa - Dipstick part # I use and after my oil change with exact numbers from my manual and how I've done it for the last 2 years it reads perfect. So I am still pretty inclined to believe it's an electronic problem and not a oil level issue, on top of the fact that the car drives and runs fine. It also stopped working shortly after I pumped about 2L of oil from my oil filter housing by mistake all over the engine and killed my alternator too...since been replaced with OEM.
Discussion Starter · #12 ·
Motor vehicle Vehicle Automotive design Car Audio equipment
Code:
                Address 01: Engine  (7P0 907 401 J)
12:55:12
  IDE00151   Oil fill level 77.992 mm
  IDE00152   Oil warning threshold 34.716 mm
  IDE00196   Engine oil temperature 67.9 °C
  IDE00699   ESI: minimum oil level in service interval 32.000 mm
  IDE00700   ESI: maximum oil level in service interval 40.668 mm
  IDE06393   Oil level: dynamic average value 39.624 mm
Code:
Friday,20,January,2023,13:04:56:06191
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: WVGDK9BP5CD005360   License Plate:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F 62
          65 69 6D 72
VIN: WVGDK9BP5CD005360   Mileage: 276395km-171743miles
08-Auto HVAC -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 J    HW: 7P0 907 401 E
   Component: 3.0TDI FSA    H17 0008
   Revision: 56H17---    CVN: 66FD96005C3E0D04D45710C1
   Coding: 292A4012233600050000
   Shop #: WSC 99918 999 00000
   ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
   ROD: EV_ECM30TDI0117P0907401J_002.rod
   VCID: 36352CB5B8C6FF4B0DF-8062
   VINID: 9E65D46C94A01535000050C60056ED4FFD
2 Faults Found:
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [039] - -
          [Diagnostic interface for data busRead out DTC]
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 276395 km
                    Date: 2023.01.20
                    Time: 13:03:20
                    Engine RPM: 754.00 /min
                    Normed load value: 42.7 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 79 °C
                    Intake air temperature: 15 °C
                    Ambient air pressure: 900 mbar
                    Voltage terminal 30: 14.120 V
                    Unlearning counter according OBD: 40
                    ACC specified acceleration: 0.000 m/s²
                    ACC control module: received status-Bits 0-7: 6
                    Active brake system error status-Bits 0-7: 0
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_RUNNING
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
4527 - Coolant Fan Control Circuit 1
          P0480 00 [039] - Electrical Malfunction
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 276395 km
                    Date: 2023.01.20
                    Time: 13:03:20
                    Normed load value: 43.5 %
                    Air mass: specified value: 234.3 mg/stroke
                    Coolant temperature at radiator outlet: actual value: 6.5 °C
                    Heat delivery temperature in cooling system: 65.5 °C
                    Outside temperature: 5.0 °C
                    Coolant fan 2: activation: 0.00 %
                    Coolant fan 1: activation: 10.00 %
                    Fuel temperature: 9.1 °C
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217)       Labels:| 0C8-927-750.clb
   Part No SW: 0C8 927 750 G    HW: 0C8 927 750 G
   Component: AL1000 AISIN  001 3407
   Serial number:                CVN: CB5A7D50
   Coding: 001368
   Shop #: WSC 02451 003 1048576
   ASAM Dataset: EV_TCMAL991031 002112
   ROD: EV_TCMAL991031_002_VW52.rod
   VCID: 30391AAD5AA2D17B573-8064
No fault code found.
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
   Component: MK25A         H36 0418
   Revision: --------    Serial number: 428410010EC010
   Coding: 5B7613C349242558DAF7C89992D2A4407700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 45D75B79F52064D3945-8010
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 4H0 907 064 BK    HW: 4H0 907 064 BK
   Component: BCM2 2.0      H31 0333
   Revision: 00002001
   Coding: 0D860000000000000000
   VCID: 73B3D5A1EBB4AA63EA1-8026
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000203802005
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BA    HW: 7P6 907 040 BA
   Component: Klima 2 Zonen H20 1203
   Coding: B686000A80
   VCID: 74B1D6BDEE3AAD5BF3B-8020
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 BD    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0100
   Revision: 15012002    Serial number: 00000001258478
   Coding: 26209093D73C5D0100201803C0005D0CC31E660882010261800000020000
   VCID: 6B83CDC1B38472A3221-803E
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110930  31  0020
   Serial number: 90243400111014150717
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10253388
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000001110110302
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R0TMR07
   Subsystem 5 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Serial number: WA102281000000492582
   Coding: 010300
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28261126901073
   Coding: 128501
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 42DD4065E40E53EBB17-8016
1 Fault Found:
1111828 - Front Left Parking Aid Sensor
          B10F7 14 [009] - Open or Short to Ground
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 226
                    Mileage: 276395 km
                    Date: 2023.01.20
                    Time: 13:03:35
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag025 H05 0025
   Revision: --------    Serial number: 003L000074ZR
   Coding: 000000000000000000000000000000003235
   ASAM Dataset: EV_AirbaVW10BPAVW526 001001
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 41DF4F69E10848F3A8D-8014
   Seat occupied recognition:
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R11727060YD
   Serial number: 3575LRB40630P13E1H2Q
   Front Passenger's Side Airbag Crash Sensor:
   Serial number: 3585LRB40630P13EB8I1
   Rear Side Airbag Crash Sensor (on driver's side):
   Serial number: 3515RRB40590NHDIJ0Q+
   Passenger side rear thorax airbag crash sensor:
   Serial number: 3525RRB405F0NS9QLHHU
   Serial number: 3555NRB40590P4N24GVU
   Serial number: 3565NRB40590P4N2M90B
Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Component: Lenks.Modul   H03 0005
   Revision: --------    Serial number: 90815KJC0008A
   Coding: 000C15
   VCID: 3829228DB252093B1F3-806C
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0119454
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 880 P    HW: 7P6 920 880 P
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658131011592001
   Coding: 033F31002B000008020004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 48C9524DC23279BB6F3-801C
1 Fault Found:
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung / Adaption]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 226
                    Mileage: 276395 km
                    Date: 2023.01.20
                    Time: 13:03:18
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000277493
   Coding: 0001037500
   GVL: FB4F40451D7B000000
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3829228DB2D2093B1F3-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650781703
Address 36: Seat Mem. Drvr (J136)       Labels: None
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000015351888
   Coding: 00581B0000004001000001010101202020202121202020
   VCID: 343116BDAE3AED5B33B-8060
Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000120773035
   Coding: 011D17205E00453005080000
   VCID: 44D1467DFE9A5DDB83B-8010
Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0161116141
   Coding: 01861E3A28F9509580A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 284119907
   Subsystem 2 - Part No SW: 7P0 959 591     HW: 7P0 959 591
   Component: J245 PS30.050  H07 0006
   Serial number:     WOO13742876
   Coding: 191100
   Subsystem 3 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
   Component: J394 PS30.050  H07 0006
   Serial number:     WOO13757827
   Coding: 191100
1 Fault Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 226
                    Mileage: 276395 km
                    Time Indication: 0
                    Date: 2023.01.20
                    Time: 13:03:20
Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000121050025
   VCID: 3B233D8183642223F21-806E
Address 53: Parking Brake
Cannot be reached
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Revision: --------    Serial number: --------------
   Coding: 010A00010F000400
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CA1FE9DC66AE51BBBB-8028
   Left_headlamp_power_output_stage:
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0002
   Coding: 130000
   Right_headlamp_power_output_stage:
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0002
   Coding: 130000
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Part No SW: 4G0 035 082 G    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0133
   Revision: AB001007    Serial number: 156J+0B7561265
   Coding: 020007020000000001
   VCID: 2411E6FD1EDA7DDBA3B-8070
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 7P6 035 664 D    HW: 7P6 035 664
   Component: H-BN-NA       H44 0706
   Revision: --------    Serial number: 445JZ0B7521362
   Coding: 010200050040A1ED43022F0E00000003F00001000000000000
   VCID: 392F278989581033E0D-806C
   Subsystem 1 - Part No: 7P6 060 884 J
   Component: NAR 2017/2018  1602
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9L79003BW
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Subsystem 4 - Part No: 8R0 060 961
   Component: CD-Database  1886
3 Faults Found:
03276 - Please Check Software Version Management
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 226
                    Mileage: 276395 km
                    Time Indication: 0
                    Date: 2023.01.20
                    Time: 13:03:20
             Freeze Frame:
                    Text: DUA001,Front,M,0,0,6
03175 - Invalid Data Set
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 226
                    Mileage: 276395 km
                    Time Indication: 0
                    Date: 2023.01.20
                    Time: 13:03:18
             Freeze Frame:
                    Voltage: 14.10 V
03623 - Invalid Security/Release Code
            000 - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 226
                    Mileage: 276395 km
                    Time Indication: 0
                    Date: 2023.01.20
                    Time: 13:03:19
             Freeze Frame:
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000121013357
   Coding: 011C17200000253005080000
   VCID: 3A2D38858C5E1B2BE97-806E
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000049696
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 3FDB499197FC3E03DE9-806A
1 Fault Found:
8397058 - Front Left TPMS Sensor
          C1050 31 [009] - No Signal
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 223
                    Mileage: 276338 km
                    Date: 2023.01.18
                    Time: 18:11:00
                    Vehicle speed: 30 km/h
                    Outside temperature: 0.5 °C
                    Reception level antenna 1: 710 mV
                    Offset level antenna 1: 630 mV
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H09 0110
   Revision: 5A001001    Serial number: 00000160252982
   Coding: 020D000000000000
1 Fault Found:
00532 - Supply Voltage B+
            011 - Open Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11101011
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 23
                    Time Indication: 0
Address 6D: Trunk Elect. (----)       Labels:| 7N0-959-107.clb
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 279100710
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D2733999DF02C13CC5-8068
Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000120929739
End----------(Elapsed Time: 02:01, VBatt start/end: 14.0V/14.0V)-----------
'14 TDI Execline
I can see out values are quite different, and I know the CATA engine has a different oil capacity, but unless another user with a CATA posts their MVBs, I'm not sure how correct or incorrect what you're seeing on yours is.
Rectangle Font Material property Technology Electronic device
Discussion Starter · #14 ·
I mean looking at this there should be no issue, and like I said manual check shows oil in the right range. I never got codes for the sensor when the original **** the bed just the same notice. I've done a reset with VCDS, and disconnected the battery for over an hour still no luck. It's just annoying at this point to be honest.
1 - 14 of 14 Posts
