1 - 11 of 11 Posts
after sorting out my gasket issues,can i clean the oil from the cooling system by using detergents??
You need to be very careful.
Some products contain ingredients that may damage the head gasket and/or the hoses.
You will also need fresh engine oil and a new filter as well as new coolant.
Run a week or so and change the oil and filter again.
If the coolant looks to have any oil in it, do a change there also.
Now i have the flashing red coolant light... im not losing any water/coolant... im suspecting the oil that was in my coolant reservoir has messed up some sensor or my electrical are bad. could i be correct guys?
Did you physically check that your coolant isn't vanishing, or are you just not seeing puddles under the car?
Discussion Starter #9
Yes, no puddles seen......I have run out of ideas on this one.Ireplaced my water pump, oil cooler...but im still getting oil in the coolant container of my r5
1 - 11 of 11 Posts
