1 - 12 of 12 Posts
Hi all,
I've had my 09 3L TDI Altitude for two and a half years and still loving the drive both on and off road.
I've made a few changes and additions to the stock setup, some of which I've modelled on others projects to date but some which I've slightly ad lib'd.
  • Wheels - downsized to 18" and upsized the sidewall with Grabber AT3s
  • removed the side skirts, de-rusted and repainted with rust treatment followed by raptor paint
  • swapped out the Altitude front and rear bumpers for the SE style ones to give better approach/exit angles
  • I got hold of a second bumper iron and welded on attachments for a winch plate onto which I've placed a 13500lb rhino winch which is wired in unfused via a dead switch under the bonnet
  • I managed to find some original cayenne side step/sill protectors which I reconditioned but I got concerned that these would be too liable to denting so they will be up for sale shortly
  • I've fabricated 3 section full length 3mm steel skid plate, a rear diff plate and a removable front bumper plate which will shortly go up to a bar attached to the tow points, this front plate and bar will only be attached for off road driving as I think it would breach the UK laws
  • I've fabricated rockslides/tree bars to prevent sill damage
Future plans
  • rear swing spare carrier
  • 2" lift
  • increase tyre diameter to the max 31"
If anyone has any pics of their spare carrier feel free to post them below so I can glean any ideas :)
Some pics off the work so far:
Winch install:
241672
241673
241671
My underbody protection - back from galvanising
241690
241691
241692
241693
For the winch ideas check out thread big bad mud tyres ... Alex made one ... cant remember how many pics he had though of work done to fab up.
with the winch install pic ..... whats the go with the little blue Ikea kids bowl on the left hand side of the pic ?
Where did you install the winch control box ? I've just had mine relocated from on top of the winch to in the engine compartment as if something dies in it i can get to it easy. I had to faff around and take the bumper off to fix PIA !!!
Love the Armour you have a bit like mine
Automotive exterior Automotive tire Automotive lighting Headlamp Grille
Only thing missing now tank guards
will make mine though ;) ;)
Reactions: C-ya and timpe
Discussion Starter · #4 · (Edited)
Thanks Odessa,
Alex’s build thread is a source of inspiration!!
The ikea bowl was to stop the rain going into the intake overnight.
My control box is mounted to the side of the winch on a custom bracket. I dismantled it and re assembled it having waterproofed it fully. At home getting the bumper off seems to only take 5 mins so not too much of an issue as lo as long as nothing go wrong off road! I’m thinking of putting an extension in for the winch clutch that would be accessible by lifting the bonnet... means I don’t have to take the grille off to release/lock.
Nice constructs for the protection... what are the plates made from? Ali?
241701
yeah aluminum 5mm i think from memory
same with the light bar can come on and off in around 2 mins ... not that you need additional lights with the HID's the touareg has as long as youve got good bulbs
Tire Wheel Automotive design Vehicle Land vehicle
just the 2 recovery points ... screwed in 2 eyelets
Are you a Facebook kinda guy ? ... Im not but if you are check out the Facebook page "Off-road VAG and Porsche "
Some sweet tregs and cayennes on there some of the gear is sweet ;)
Reactions: Chris Anderson
(y) (y)
Timpe this is an off the shelf solution that suits me down to the ground. Can still tow and fit the bike rack. Bit of a hassle to drop it down and raise back up (drops to left or right) has a extendable handle to increase lift leverage but I don't need to use it. Can't recall exact towing capacity but by memory drops rating down to 2/3rds original. As a bonus works as a ladder to load roof racks.
241821
241822
241823
241824
241825
Discussion Starter · #12 ·
Such a good concept - hadn't thought of dropping it to the side...
You guys get the benefit of the 2inch receiver whereas we get a custom towbar vertical attachment option... your's is I believe much more versatile to add on to.
I suppose I could try and find a alternative rear bar?
Tim
1 - 12 of 12 Posts
