1 - 2 of 2 Posts
Hi all,
When I get in the car and start it the interior light above the right side rear door goes on and stays on. It does go off with the other lights when I remove the key and exit the vehicle. Wth is the deal?
Banned
R5 (2008)
If the original bulb in the affected light was a halogen one and you replaced it with a LED, then this might be, because there could be residual voltage in the circuit of that light, which wouldn't be enough to drive a halogen bulb (which the circuit was tested for), but will illuminate a LED. Or if you have the light assembly with a switch which allows you to manually control it, maybe it's set to stay on.
1 - 2 of 2 Posts
