1 - 10 of 10 Posts
Hi! I would apreciate your help!
I have a 2007 V6 3.0TDI Touareg, and I have already spend 1.500€, and the problem pressists!
When the car is coold it start's without at 1st! After driving, if I stop and try to start imediatly it starts also at 1st!
Howerver, if I wait 10 min, it won't start! the starter runs for 2 seconds and then nothing! only after 30 min!
I´ve already changed the battery, starter, temp sensor and I still I've the problem!!
I've read in a post it could be "clogged up flap in what is the EGR valve assembly". Do you think it coud be my problem? Why it only happens when the car is warm??
I thank you in advance for your help...
Try also posting your problem on the UK site to widen your audience:
www.mytreg.com
Failed G28 engine speed sensor.(guaranteed)
LHS rear of engine down low.
Fairly easy to get
VW# 070 957 147 (off course expensive for a VW box holding a Bosch sensor)
Bosch # 0 261 210 261 (1/3 of the price)
All T1 and T2 V6 tdi owners should get this replace after about 180,000 kms
Regards
Drag
Thanks Drag!
I will try to replace the "G28 engine speed sensor" tomorrow!
I realy hope you are right! I will give feedback after!
Regards,
Gil
Discussion Starter #9
You were right!
Problem solved!
engine speed sensor (G28) with problems
After replacement, no problems in starting when engine is warm!
For my Touareg V6 3.0 TDI (BKS), 2007, the PN is VW # 077905381K
Many thanks for your tip!
Regards,
Gil
Discussion Starter #10
I was hopping that maybe with the replacement of this engine speed sensor G28, the other problem that I have could be solved, but unfortunately not!
My cruise control does not activate! Also no errors on the VDS!
Drag!
Do you have some tip also to this one?
Regards,
Gil
1 - 10 of 10 Posts
