1 - 3 of 3 Posts
Hello All.
I have a 2005 Australian delivered duel zone climate control Touareg.
Recently it burned out the brushes in the A/C motor, I have swapped the unit out, however now I have no air being blown from the vents.
Both Hot and Cold it make no difference, nor does air recycle function. Auto or manual, no change.
LCD's on both sides of the climate control system is functioning, as is the fan speed controls buttons.
Fan running happily, however, no air flow from the vents. Is there a sensor I could have knocked off, or a fuse I could have blown?
Any Ideas Club Touareg members??
Chris,
Do you mean you have installed a new fan motor in the heater unit in the car?
If so, where did you buy the replacement from?
The reason I ask is that the old memory banks are recalling that I read somewhere that it is possible that fans for left hand drive cars run in the opposite direction to those for right hand drive cars but both fit the wrong car.
On the other hand I might be spouting bollocks!
1 - 3 of 3 Posts
