181 - 200 of 205 Posts
Hi Tim,
Thank you so much for very thoughtful and detailed write up. You took a lot of your time to write that up and I really appreciate it.
I feel like I have done everything as you said. I took some pictures of the card files. I actually tried it on 2 different SD 32gb cards to see if maybe it just didn’t like one.
I took some screen shots. I will attach them. I noticed it said that it’s a file folder but don’t see where I can change that and figure maybe that part is ok. Your help is much appreciated. Really thankful for nice people like you.
Thanks,
Brandan
I think I might have figured out what I did wrong Tim. I didn't rename the volume label and was just renaming the actual files. I will try that and see if it works. Thanks again for taken the time to help a computer numbskull such as myself. I owe you one. LOL...although not sure you would ever need my help. I am kindof an amateur.
sorry if this is in wrong section but I would like to get Navigation working again. I dont understand why I lost my database or maybe the configure is incorrect for my region and chassis type and is not recognizing when commanded. My green menu is active. Is there a database solution within green menu options? I have crosschecked and recoded 5F multiple times. My vcds 5F remains 03675, Nav Data invalid. I am not very confident when it comes to flashing and uploading critical data. Are the PDFs written for novice computer users?
Let me know if it works.
Your last picture of the SD card shows that you still have folders on the SD card.
You just gave the contents a
You don’t need the green screen for updating the navigation.
What is the version of your system?
To check the version number:
SETUP > System > Version information
Hi Tim,
I noticed that the images you posted also showed that VW and pkgdb folders. So maybe thats ok? Those were on there, I didn't do anything to those.
I have to try the install...but after my first attempt I realized that my trickle charger may not be enough to keep the battery up and I really don't want to run it for 3 hours..so gotta figure out what to do there. Last thing I want is for it to die part way through. I appreciate all your help. You are a good guy.
Cheers,
Brandan
🤔 Your systrm behaves differently from my 2014 Touareg.
Maybe try and hold PHONE+SETUP at the same time.
I found that combination from the thread entitled
“RNS850 v722 Update for MY2011-2013”
It is likely that you will need the information from that thread to update the system to v711 before trying to apply the navigation update in this thread.
Hope this is helpful and you get success from the instructions in the other thread.
Hi Tim,
Cheers,
Brandan
@Brobb - Did it work this time?
Hi Tim,
Thanks for checking on me. I haven’t tried it yet but might this weekend. I am a little concerned about the battery since I found out my trickle charger won’t be enough to keep the battery charge during upload. Gonna be pretty boring having to sit in the vehicle the whole time to make sure I start it and run it while it’s uploading but I may have to do that. I will let you know how it turns out. Thank you and have a great day.
2011 Touareg Exec
I did this update about 2 weeks ago on my 2011 exec. The firmware update went smoothly, and I moved on to update the maps.....which also went smoothly. But I was never able to update the activation. The system seems to be working properly, but when I scan with VCDS, I get the following errors. Any suggestions?
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 207760 km
Time Indication: 0
Date: 2020.02.11
Time: 13:39:36
Freeze Frame:
Text: DUA001,Front,M,0,0,6
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 29
Mileage: 207760 km
Time Indication: 0
Date: 2020.02.11
Time: 13:39:35
Freeze Frame:
Voltage: 12.10 V
03623 - Invalid Security/Release Code
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 207760 km
Time Indication: 0
Date: 2020.02.11
Time: 13:39:35
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
I just connected my small battery maintenance charger and it was fine. Switched A/c and climate control off, in fact everything off. Then i left the car with the ignition on for the media upload so the only thing active was the media system.
Eventually the fuel pump and running lights eventually turned themselves off sometime during the 3 hours and the battery was fine.
Good luck with the upload.
Thanks Tim..I will give it a go this weekend. I just got alittle concerned b/c last time I was trying..for a couple of hours..on the trickle charger..I noticed it flashed up and said battery was low to start the vehicle or it would shut off in 3 minutes. But it had been parked for a couple of weeks building up to that. So that might have been part of it.
So we still haven't seen the V13 version of the north american maps come out yet.
I'm still hopeful that it could still come.
But rather than charge people for the V12 maps update, I decided to give back the my favorite community.
You will need the following:
0711 firmware or higher
32gb high speed SD card
battery charger and/ or enough fuel to have your vehicle running for 3 hours
a windows PC using the native unzip utility to unzip the folder
The instructions are inside of the zipped folder.
This link is good for ~7 days, i'll keep uploading and posting new links to keep this going...
Enjoy my friends :grin2:
Download files - Filemail
Can I get a link to download the latest version. Thanks
Thanks YRKTREG for all the info and the updates!
Ditto... sorry for coming a bit late to the rodeo here... definitely want to do this upgrade to my 2013 TDI Exec... has anyone also done the Naviplus or JoyeAuto CarPlay upgrade... wondering if I should do the update / upgrade you guys are discussing here first before adding new CarPlay hardware!?
My Firmware and map updates were successful. However does anyone know the coding to remove these errors for the RNS850 5F - Infotainment Module:
Part No SW: 7P6 035 664 D HW: 7P6 035 664
Component: H-BN-NA H44 0706
Revision: -------- Serial number: 445CZ0C7530548
Coding: 010200050040E1ED41022B0E00000003F00001010000000000
Shop #: WSC 31414 790 00001
VCID: 39791D79B036F787A2-806C
Subsystem 1 - Part No: 7P6 060 884 J
Component: NAR 2017/2018 1602
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9L79003QT
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
3 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 14
Mileage: 185463 km
Time Indication: 0
Date: 2020.02.23
Time: 07:59:39
Freeze Frame:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 14
Mileage: 185463 km
Time Indication: 0
Date: 2020.02.23
Time: 07:59:37
Freeze Frame:
Voltage: 12.40 V
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 14
Mileage: 185463 km
Time Indication: 0
Date: 2020.02.23
Time: 07:59:37
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
