04 V8 90K
Third time this has happened. Driving for several hours , cruising 85 MPH+ , 105+ degrees out. All of a sudden I get no throttle, car hesitates, power comes back, but problem get progressively worse until it almost stalls. Let car sit for 15 minutes, restart and car will drive fine again for a while.
I scanned with VAG and only faults are for MAF (no CEL).
The truck is almost acting like ESP is intervening, but no faults in ABS.
Anyone help? THis is a tough one as there is no corresponding fault codes and only happens after several hours driving in high temperatures. I was thinking maybe the TPS, fuel pressure, pedal position sensor but all that should leave a fault...
