Hi all,
I've got the above error on VCDS and have taken the dashboard off and got the actuator out. I've taken it apart and "visually" it looks fine, there's no worn cogs and the board looks ok so am i right in thinking that it has just "lost" it's settings and if so is there a way to put these back ?
I did put it in service mode and then got it to re-learn a couple of times but the error still shows.
I'll get a replacement if needs be but if there's a quick fix for this with VCDS then that'll be quicker.
Ian
The adaptation does not occur through putting the flaps into service mode, but through the Basic setting functions in the HVAC control module. Have you used that?
Yeah, you mean to "re-learn" yes, i've done that. I'm suspecting then that the actuator is dead but would've though the error would've been different ?
