My egg will no idle for more than 30 seconds when "cold" starting it dies. Its weird because when starting from cold cold overnight and below zero it idles fine. But when ambient temperatures are above 0 degrees C it will die on idle and at stops until it is driven on the highway for some time. After driving the highway for 20-30 mins it can idle for hours no problem. I have changed the PCV valve recently, vacuum leaks have been fixed, the engine speed sensor was done I swapped it with a wrecker part as it had a code but after replacing it went away mind you there is still a CAM code on the car as seen below. I have also taken the 404 relay out and idled the car but it still died the sound when opening the door I did not hear when this happened today but it could be because it was running for a while. I measured groups 208 and 209 for the chain as I was curious about the stretch, 208 shows a perfect -10 and 209 does not show any reading as seen in photos. Any ideas? It is currently at the mechanics now he will look at it again for me, we also tried switching in the old speed sensor as I left it hanging there and the P1340 came back and it still did not idle, he still thinks its the engine speed sensor but with the wrecker part in there the code P1340 was not there anymore... We will swap in a new one this week but I want to pick your guys brains for other ideas before hand. I also want to know why 208 is showing a perfect -10 and 209 nothing likely because the G28 sensor is bad?
Here are the codes:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGBG67L65D050758 Mileage: 197580km-122770miles
Address 01: Engine Labels: 022-906-032-BMX.lbl
Part No SW: 022 906 032 FT HW:
Component: MOTRONIC ME7.1.1G 6388
Revision: 00000000 Serial number: VWZ3Z0D5290123
Coding: 0000133
Shop #: WSC 31414 000 00000
VCID: 629DB9DF78559E3B9D6-5160
VINID: 9E65D25C61DC1855001401C5202B884CCB
2 Faults Found:
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
P1347 - 002 - Incor. Correl. - MIL ON
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
P1340 - 002 - Incor. Correlation - Intermittent
Readiness: 0100 1000
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 BA
Component: AL 750 6A 0556
Coding: 0004153
VCID: 6E85DDEFBC8D2A5B09E-5160
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0014338
VCID: 3D272AA3A16B81C3C04-5160
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 P HW: 5WK 470 25
Component: Kessy 6610
Revision: 66105312 Serial number: VWZ3Z0D5290123
Coding: 0000232
VCID: 323D099F68354EBB2D6-5160
Component: ELV XXXX
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0000030
VCID: 35373283995B5983084-5160
2 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
000 - -
01592 - Air Quality Sensor (G238)
007 - Short to Ground
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component: 3001
Coding: 0101599
VCID: 46D5454FF4BDC21B91E-5160
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
00907 - Intervention load Management
000 - -
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0C Airbag 8.4E+ H10 0952
Coding: 0012355
VCID: 2517E2C329FB2903B84-5160
Part No: 7L6 953 549 E
Component: Lenksäulenmodul 3301
Coding: 0000231
VCID: 41DF5653DD93E523A4C-5160
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 870 T
Component: KOMBIINSTRUMENT RB8 2010
Coding: 0007331
VCID: 47CB484BF3B7DB136A8-5160
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9C397A6B93CAB1B2-5160
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
Shop #: WSC 00000 000 00000
VCID: 45D74243C9BBC903984-5160
Address 22: AWD Labels: None
Part No: 0AD 927 755 AJ
Component: TRANSFERCASE 0100
VCID: 03539C5B870F3733F60-5160
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000001
VCID: 6695A5CF947DE21B71E-5160
1 Fault Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Address 36: Seat Mem. Drvr Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0702
VCID: 77ABF88BC3D76B93DA8-5160
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000002
VCID: 678BA8CB9377FB134A8-5160
1 Fault Found:
00774 - Level Control System Sensor; Rear Left (G76)
008 - Implausible Signal - MIL ON
Part No: 7L0 959 933 E
Component: H4 HSG 0200
Coding: 0000085
VCID: 3E252DAFAC6D9ADBD9E-4B1E
Subsystem 1 - Part No: 7L0 959 701 G
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 G
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
2 Faults Found:
00926 - Terminal 30
011 - Open Circuit
01134 - Alarm Horn (H12)
000 - -
Address 47: Sound System Labels:
VCID: 55F792033C0B7983E84-5160
Note: Excessive Comm Errors
Address 56: Radio Labels: 7L6-035-180-56.lbl
Part No: 7L6 035 180
Component: Radio DE2 0009
Coding: 0001035
VCID: 6A8DD1FF8065C67B556-5160
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000855
Shop #: WSC 31414 000 376832
VCID: 3C2127A7BA7188CBF7A-5160
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 E HW: 7L0 907 383 E
Component: ANHAENGERELEKTRONIK 8254
Coding: 0000002
Shop #: WSC 93022 999 52576
VCID: 3635358F845D529B01E-5160
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 K
Component: DACHDISPLAY 0538
Revision: 00700538 Serial number: 2009289.06
VCID: 3FDB50ABAB6793D3D28-5160
End----------(Elapsed Time: 08:34, VBatt start/end: 13.9V/14.0V)-----------
Here are the codes:
Coding: 0000133
2 Faults Found:
Coding: 0004153
Coding: 0014338
Coding: 0000232
Component: ELV XXXX
Coding: 0000030
2 Faults Found:
000 - -
Component: 3001
Coding: 0101599
2 Faults Found:
000 - -
Coding: 0012355
Coding: 0000231
Coding: 0007331
Coding: 0000006
Coding: 0000001
1 Fault Found:
Coding: 0000002
1 Fault Found:
Coding: 0000085
2 Faults Found:
00926 - Terminal 30
011 - Open Circuit
000 - -
Coding: 0001035
Coding: 0000855
Coding: 00217125
Shop #: WSC 31414
Coding: 0000002
