1 - 14 of 14 Posts
My 2016 with 88k has no heat, not even slightly warm air. I looked at other threads about the same issue and thought the heater control valve may be the culprit so I pulled the fender liner tonight. The valve looked fine but with the car at operating temp there was no coolant going to or from the valve.
There are no visible coolant leaks, no overheating issues, and the coolant reservoir is at the bottom line when hot.
My next step was going to be topping of coolant and seeing if I can get any air bubbles out and if that doesn't yield results maybe flushing the system. Any input would be appreciated!
2011 VR6 FSI LUX
If the heater control valve for the heater core is stuck in the closed position the coolant might stay cool at both sides due to the coolant not being able to flow.
There was a member on here who realized theirs was stuck closed when they bypassed that valve with a piece of hose and got heat back. I'm not sure how mechanically inclined you are and I'm not saying it's going to fix the problem but it's a good test.
If you do flush the coolant, which VW says should be done every 30K miles or 2 years, it should be refilled using a vacuum type of tool so as to not get any trapped air.
I saw that thread but I thought I misread it. I assumed a blockage at the valve wouldn't affect the coolant flow from the engine but maybe it formed some sort of air pocket?
That's good to know about the vacuum tool to flush, I don't have shop air so I might take it to a shop to do that first.
The car is new to me and the coolant looks fine but I doubt was done every 2 years.
Ac work good? Could be blend door
2011 VR6 FSI LUX
If it were a blend door problem wouldn't the OP still have heated coolant in the hoses on each side of the heater core control valve?
Good catch. You're right
2011 VR6 FSI LUX
I think if there's a blockage or the valve is stuck closed it basically becomes dead headed and the coolant doesn't flow. A stuck air pocket might do that but I thought these vehicles would eventually burp themselves if the heat is turned to max and idle is at 2k for a few minutes. Definitely make sure the coolant in the reservoir is at the max line prior.
If the coolant system has been cracked recently I can almost guarantee it needs burped. Huge pita on these
Well I had the dealership flush the coolant and still no luck. I am sort of stumped now.
Did they flush before or after these issues started
2011 VR6 FSI LUX
Something is stopping the coolant flow to/through the heater core. If you're going to diagnose this yourself you're going to have to get the vehicle to temp and check all coolant hoses to see which ones are warm/hot and which ones are not, aside from the two you already know are not.
I know on my '11 there are two other "heater/coolant" control valves. I believe they are vacuum operated. They are #23 in the picture below which is for 2011-2017's. One I know for sure is on the drivers side of the engine towards the back. The other is on the passenger side but I'm not sure where exactly as a shop changed this one and I didn't see it.
You'd have to see if the hoses on each side of them are warm/hot and also verify if there is vacuum on the line attached to them.
Organism Font Line Parallel Auto part
Touareg 7P 3.0 TDI 2010 240HP
I had the same problem on my '11 Touareg 3.0 TDI and sent my car to the service shop. They only charged me $50 (Services are cheap in Albania) and the reason of that was blocked valves and water hoes( I dont exactly know which ones). Now it blows flaming hot air after that little fix.
1 - 14 of 14 Posts
