BKS engine.
Installed new swirl flaps in the lower inlet manifolds. To do this I had to remove two high pressure fuel pipes connecting the HPFP to the left fuel accumulator and the high pressure fuel connecting the left hand accumulator to the right hand accumulator and the plastic fuel delivery line to the HPFP.
I have bleed the system IAW eWin 1.11 Bleeding the Fuel System.
Treg refuses to start. I have fuel flowing from the low pressure pump at the inlet to the HPFP and also from the return from the HPFP.
Nothing from the high pressure side. No faults are showing in relation to the fuel system. (I only have an ObEleven app which will show and clear faults and test outputs.)
What have I missed and any ideas?
