True or not?
The tube is on the right hand front of the engine -capped.Which oil cap cover the dipstick tube - where is the tube?
Both my 650 and 535 have level sensors, and both are plagued by false positives, ie, low oil warnings when, in fact, the oil level is fine. Adding an extra qt or two to a full pan could result in aerated oil, a lousy lubricant, which could shorten the life of an engine. BMW claimed that the occasional air bubble in contact with the sensor could lead to the low oil warning. I have my doubts, but if true, that would only undescore the need for a dipstick. If all you have is an virtual dipstick, it has better be bullet proof.I have a question- Has anyone,anywhere,ever heard of a oil level sensor failing and it causing damage to the engine?
Vehicle still has a oil pressure warning system. Can't speak for other makers but Porsche monitors the operation of the oil level sensor and if it's implausible then a fault is triggered.The key thing is, can you be 200% certain that if your engine oil level sensor failed, you ran the engine dry and wrecked it, would VW pay?
Or would you get the brush off.
Now let me think about that for, well, all of one nanosecond.
What's the part number for the dipstick?
[P.S. A dipstick in UK slang is someone who is very, very stupid, but in this case I think a dipstick is a VERY wise idea!]
X3, and I'll add that checking your oil level via the dipstick means getting under the hood periodically. You'd be surprised what you may find that could prevent probs down the line.X2 on C4ar's comment, you see if the oil is dirty, milky (coolant contamination) or smells like diesel (fuel contamination, in a diesel a VERY bad thing).
Is this confirmed? If the physical dipstick returns a reading of oil level that doesn't agree with the electronic sensor I'm having trouble seeing its value. I as the primary driver of the vehicle may know "The dipstick reading is wrong by this much" but anyone else who checks the oil level via dipstick could innocently conclude the level is low, add more oil, and now you're overfilled.FYI, if you add the dipstick above, it will read about 1/2 Qt lower than the electronic sensor. Not sure which is correct.
The tube would not have changed from the earlier 09-10 TDI motor which did have a dipstick. All they did was put a level sensor in and a cap over the diptstick tube. So I would be more prone to believe the dipstick then the sensor.Is this confirmed? If the physical dipstick returns a reading of oil level that doesn't agree with the electronic sensor I'm having trouble seeing its value. I as the primary driver of the vehicle may know "The dipstick reading is wrong by this much" but anyone else who checks the oil level via dipstick could innocently conclude the level is low, add more oil, and now you're overfilled.
?? I would like to get the dipstick but if it's not accurate...
