1 - 16 of 16 Posts
I have recently bought an 07 V6 Treg (my first Touareg/VW/diesel/4x4) and promptly realised I needed to re-insulate the entirety of the inner headlight looms when I investigated the no bend lighting message.
Both headlight connectors have been butchered by a/the previous owner but seem to fit in quite snug.
I found a guy that does Ross tech vag-com scans for $50 and got one done
Code:
Friday,29,May,2020,04:01:18:01010
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WVGZZZ7LZ7D080456   License Plate: PETE
Mileage: 235700km-146457mi   Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 37 46 55 56 68 69 76
VIN: WVGZZZ7LZ7D080456   Mileage: 235700km-146457miles
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
68-Wiper Electr. -- Status: Sporadic communication error 1000
69-Trailer -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 7L0 907 401 D    HW: 7L0 907 401 D
   Component: 3.0L V6TDI  G000AG  0030
   Revision: --H04---    Serial number: VWX3Z0G1599727
   Coding: 0011779
   Shop #: WSC 66565 257 00032
   VCID: 2C01021CFA1B084BDF3-5184
No fault code found.
Readiness: 0 0 1 1 1
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 FA    HW: 09D 927 750 FA
   Component: AL 750 6A           0992
   Revision: 00H61000    Serial number:
   Coding: 0004456
   Shop #: WSC 31414 790 00001
   VCID: 72BDDC6418BF1EBB55F-5160
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth.        Labels: 3D0-909-13x-05.lbl
   Part No SW: 3D0 909 139 B    HW: 5WK 485 04
   Component:    Kessy            6840
   Revision: 68406418    Serial number: VWX3Z0G1599727
   Coding: 0000232
   VCID: 2809FE0CEEB3246B3BB-807C
   Component: ELV                 XXXX
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   Shop #: WSC 00000 000 00000
   VCID: 77ABED70738D7B93621-8022
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 AD
   Component: CLIMAtronic R/L     4326
   Coding: 0020520
   VCID: 72BDDC6418EF1EBB55F-8026
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2000
   Revision: -0004---    Serial number: --------------
   Coding: 400004002B021C000000000000000000
   VCID: 005986AC26433C2B53B-8054
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234  39 VW8T       0250
   Revision: 92011025    Serial number: 003>0X15V0U
   Coding: 0013113
   VCID: 7AADF444409F66FB1DF-802E
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 F
   Component: Lenksaeulenmodul    3501
   Coding: 0010012
   VCID: 42DD4CA468CFEE3B05F-8016
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 885 J    HW: 7L6 920 885 J
   Component: J0285 KOMBI-INST.   7018
   Revision: KHH06X62
   Coding: 0007101
   Shop #: WSC 40139 067 57207
   VCID: 43D349A07795E7330E9-8016
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 885 J
   Component: J533  GW-K-CAN TP20 7018
   Coding: 77E2EF8F48046003
   VCID: 70B9D66C16A32CABA3B-8024
Address 22: AWD        Labels: None
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F5B05505BED43D32A1-5160
Address 36: Seat Mem. Drvr        Labels: None
   Component: Sitzverstellung     0703
   VCID: 77ABED7073DD7B93621-5184
Address 37: Navigation
Cannot be reached
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L6 959 933
   Component: 12 HSG              7124
   Coding: 0000065
   Shop #: WSC 34958 000 1048576
   VCID: 7F5B05505BED43D32A1-4B1E
   Subsystem 1 - Part No: 7L0 959 701 R
   Component: Tuersteuergeraet FS 6302
   Subsystem 2 - Part No: 7L0 959 702 R
   Component: Tuersteuergeraet BF 6302
   Subsystem 3 - Part No: 7L6 959 703
   Component: Tuersteuergeraet HL 0202
   Subsystem 4 - Part No: 7L6 959 704
   Component: Tuersteuergeraet HR 0202
   Subsystem 5 - Part No: 7L0 907 719 A
   Component:    Neigungssensor   0020
   Subsystem 6 - Part No: 7L6 951 171 B
   Component:    Innenraumsensor  0020
1 Fault Found:
01134 - Alarm Horn (H12)
            000 - -
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
   Component: AFS-Steuergeraet    X014
   Revision:   H01       Serial number:
   Coding: 1286403
   VCID: 392F2B480519ADE3545-806C
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X008
   Coding: 00000019
   Subsystem 2 - Part No: ID-R fehlt    Labels: ID-55-02.CLB
   Component: AFS-Lst.-Modul r    ....
   Coding: 00000255
5 Faults Found:
02234 - Right Headlight Power Output Stage (J668)
            004 - No Signal/Communication - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 191
                    Mileage: 235702 km
                    Time Indication: 0
                    Date: 2020.05.29
                    Time: 16:58:32
             Freeze Frame:
                    Voltage: 11.93 V
                    Speed: 0.0 km/h
                        ABS 1
01042 - Control Module; Not Coded
            000 - - - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 191
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 - - - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 191
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 - - - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 191
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
01539 - Headlights Not Adjusted
            005 - No or Incorrect Basic Setting / Adaptation - MIL ON
             Freeze Frame:
                    Fault Status: 11100101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 191
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
   Part No: 7L6 035 186 G
   Component:        Radio        0013
   Coding: 0010432
   VCID: 372B2D70334DBB93A21-8062
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 A
   Component: J400__ Front Wiper  5101
   Coding: 0000341
   VCID: 38292E4C3E53B4EBABB-806C
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     120407 020  0105
   Coding: 00208933
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   Coding: 0000001
   VCID: 38292E4C3E13B4EBABB-806C
Address 76: Park Assist        Labels: Redir Fail!
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
End----(Elapsed Time: 02:43, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Sent from Mail for Windows 10
I have a plan to find the fault and a couple of questions!
My plan is to swap the headlight modules from left to right and vice versa and go and grab another scan and hopefully this will tell me if the non communicating module swaps sides on the scan then I can simply replace the faulty module but if not I need to find faulty wiring.
My questions are ... Will this work swapping sides with the modules and re scanning and secondly can I replace a faulty module with one of the same part number from another VW and then recode?
The headlights work on low and high beam, low beam is super low and wouldn't want to drive at night on a highway.
Cornering bulbs looked good when I re-insulated the looms, the lamps don't do the calibration dance... I'm looking forward to seeing it.
I read here on Club Touareg for a week before posting... Yep, I've used the search function and wouldn't have even known vag-com was a thing, it's all a lot to learn.
Thanks for any advice in advance.
Pete.
Pete
early T's had woeful lights
Does yours have HIDs ... if not ... lights are crap !!
.... even with my early 05 V8 when i installed aftermarket HIDs they were not that great .... slightly better than stock H7 but still sh :) t !!!
Swapping theory ... sounds like where i would go for starters but electrical voodoo stuff is beyond me
Welcome to the forum.
Let’s start by first getting you a nice vcds cable. That’s vagcom there. 199$ and you’re your own dealer concerning scans and fault finding.
Don’t go spending 50$ on every scan. You need a computer to install the vcds software. A windows laptop or a windows tablet is fine. Careful if you go for a windows tablet as you need the desktop version pf windows.
If money is not an issue you can even get the wireless version but that’s up you. 199$ for the real genuine cable and you’re good to go. I’ll come back concerning your lights issue. I replaced mine with a set if used units from ebzy. All good so far. The xenon bulbs go bad after a while you need to replace them. Oems are expensive but they are supposed to last 10+ years. You can test with a cheap pair from amazon based on feedback. 20 or 30$ to troubleshoot and see if the reflectors are ok and if you get good lighting.
Yep it has working zenon lights it's just the curve/bend parts that doesn't work.
I will also consider grabbing the vag com cable I'm just not sure if my laptop will run it.
It runs on most of the windows version. What are you running?
You can contact rosstech and inquire.
The wiring on the headlight is known for going bad and start crumbling. How is the insulation on the wires.
I don’t think you can swap module. If the lights are working you need to clear all codes and scan again.
I had to heatshrink all of the internal wiring in the headlights
237596
So the insulation is all good now.
All the codes were cleared before the above scan.
I just need to either fix other wiring or replace the module before 55 headlight range can be coded.
Per the Ross tech wiki.
What I usually do is get a cheap used part from ebay and test it. Just get the exact same part with same ending letters even if in your case it’s not critical.
I’m talking about the ballast if that is what you want to swap. Part number is 5M0907391 but you double check on your treg. Get a cheap used one from ebay for 20$ and test.
Discussion Starter #9
I am talking about the Part No: 7L6 941 329 B headlight range modules,
In the scan it shows the right one isn't connecting/communicating.
237616
I see. Were you able to plug it on the other side? Next option to determine if it’s the unit or the wiring is either continuity tests as far as you can go or a used unit from ebay.
Discussion Starter #11
I will try swapping them after the school run, hopefully they will swap and find that the rhs module is kaput because I'm not looking forward to continuity tests on Treg wiring.
If they do physically swap I will get another scan done this afternoon.
I have a used one on my watchlist on eBay
Pete.
Discussion Starter #12
They do physically swap quite easily so I will see what the info the scan provides this afternoon.
There is no mention of right vs left of that module so it might come up alright in a scan whether is is mounted left or right.
Discussion Starter #15
Well the scan showed the same fault for RHS module so the modules are good and I need to fault find the connections and wiring.
This means I will 100% be buying the cable because I can't warrant paying for a scan everytime I think I may have fixed a connection etc.
The legend that done the scans didn't take my money for this afternoon's scan.
Once I have a cable of my own I might see if I can swap the whole headlight assemblies and connect them up just sitting in the engine bay that will straight away tell me with a scan if the internals are shot in the rhs headlight (or perhaps a misplaced pin in a connector when I re-insulated the wiring.
Pete.
1 - 16 of 16 Posts
