Here is my first scan anything I should be concerned about I'm trying to fix the AC by deleting the code saying loss of pressure i've seen a few guys on here have that work for them.
Other than that is there anything that stands out to you guys that I should address I'm new to the whole vag com.
Wednesday,08,June,2016,18:02:24:42678
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
www.Ross-Tech.com
VIN: WVGPT77L77D008612 License Plate:
Mileage: 253950km-157797mi Repair Order: V10 6-8-16
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGPT77L77D008612 Mileage: 253950km-157797miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 CQ HW: 028 101 196 2
Component: V10 5,0L EDCG000AGMª8472
Revision: --H02--- Serial number: VWZ3Z0F2496194
Coding: 0060575
Shop #: WSC 66565 257 00032
VCID: 61C9D00FBBEF1C3611-5140
1 Fault Found:
012295 - Camshaft Position Sensor (G40)
P3007 - 000 - No Signal - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 208
Reset counter: 255
Mileage: 250019 km
Time Indication: 0
Freeze Frame:
RPM: 189 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.41 V
Bin. Bits: 00001011
Idle Stabilization: 0.0°KW
(no units): 32.0
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 DP HW: 09D 927 750 DP
Component: AL 750 6A 0856
Revision: 00H51000 Serial number:
Coding: 0004216
Shop #: WSC 31414 000 00000
VCID: 7F0D76772D5BCAC607-5140
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0022786
VCID: 3D714C7F67D718D655-5140
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 135 A HW: 5WK 485 01
Component: Kessy 6700
Revision: 67006015 Serial number: VWZ3Z0F2496194
Coding: 0000232
VCID: 2F6D6637BDBBFA46D7-5140
Component: ELV XXXX
Part No: 7L6 907 040 T
Component: CLIMAtronic R/L 4222
Coding: 0020030
VCID: 4189308F1B2F7C3631-5140
1 Fault Found:
00445 - Loss of Refrigerant
000 - -
Freeze Frame:
Temperature: 79.0°C
RPM: 928 /min
Absolute Pres.: 5.0 bar
Load: 46.0 %
Temperature: 16.0°C
Temperature: 29.0°C
Load: 4.8 %
Temperature: 94.0°C
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 N
Component: 3002
Coding: 0110815
VCID: 479D2E97350B4206FF-5140
2 Faults Found:
00907 - Intervention load Management
000 - -
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal - Intermittent
Address 11: Engine II Labels: Redir Fail!
Component: V10 5,0L EDCG000AGSª8472
Coding: 0060575
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 05 Airbag 8.4E++H01 0562
Revision: BB38727 Serial number: 0008466>
Coding: 0012341
VCID: 285F8D2B9855AD7E16-5140
Subsystem 1 - Part No: 7L0 959 339 C
Component: BF-Gewichtsens. 006 0008
2 Faults Found:
01316 - ABS Control Module
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 17
Reset counter: 255
Time Indication: 0
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Part No: 7L6 953 549 H
Component: Lenksäulenmodul 3401
Coding: 0010031
VCID: 4487399B043D691E1A-5140
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 981 R
Component: KOMBIINSTRUMENT RB8 3211
Coding: 0007231
VCID: 489F2DAB38154D7EF6-5140
1 Fault Found:
01304 - Radio
Address 18: Aux. Heat Labels: 7L6-819-008.lbl
Part No: 7L6 815 071 D
Component: Standheizung E1MAC
Coding: 0000100
VCID: 33656A475193DEA6B3-5140
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70EFA54B6005A5BE8E-5140
1 Fault Found:
01304 - Radio
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
Shop #: WSC 00000 000 00000
VCID: 4581249F0F0750160D-5140
Address 22: AWD Labels: None
Part No: 0AD 927 755 AT
Component: TRANSFERCASE 0114
VCID: 0D11DCBF17F7E85605-5140
Address 32: Differential Locks Labels: None
Part No: 0AC 927 771 C
Component: SG-Quersperre 5020
VCID: 387F5D6B48F53DFE86-5124
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 H
Component: LUFTFDR.-CDC- 3C3P1 3099
Coding: 0015521
VCID: 387F5D6B48F53DFE86-5140
Address 36: Seat Mem. Drvr Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0702
VCID: 77FD9E57056BF2864F-5140
Part No: 7L0 959 933 H
Component: YM HSG 0400
Coding: 0000085
VCID: 4189308F1B2F7C3631-4B00
Subsystem 1 - Part No: 7L0 959 701 G
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 G
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
1 Fault Found:
00988 - Lamp for Brake Light; Right (M10)
009 - Open or Short to Ground - Intermittent
Address 55: Headlight Range Labels: 7L6-907-357.lbl
Part No SW: 7L6 907 357 HW: 7L6 907 357
Component: AFS-Steuergeraet 0003
Revision: H09 Serial number:
Coding: 0000009
VCID: 78FF9D6B0875FDFE46-5140
Subsystem 1 - Part No: 7L6 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X018
Coding: 00000034
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X018
Coding: 00000034
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000341
Shop #: WSC 31414 000 376832
VCID: 3C77417B7CCD11DE62-5140
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 071006 020 0105
Coding: 00208933
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000002
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 7L6 959 107 HW: 7L6 959 107
Component: J605 HECKKLAPPE 1110
Revision: --H05--- Serial number: --------003376
Coding: 0022110
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 T
Component: DACHDISPLAY 0539
Revision: 00900539 Serial number: 2009289.07
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 3979586F73FF24F679-5140
End-------------------------(Elapsed Time: 08:01)--------------------------
