Hi All!
I've found myself to be the owner of a 2007 facelift V10.
I've not had the time to be involved in previous car forums for a long time but a change in circumstance means i should be able to start poking my nose around in here.
I'm not going to pretent I'm a pro and I will trfy to get more involved but I can only start with good intentions!
A little bit of the story so far is not a great one sadly.
I found the car, inspected it, and did pretty well I thought...
Known issues where all cosmetic
a little bit of bodywork previously done on a wing
dent on the rear wheel arch to push out (and then further assess)
some of the interior switch gear is rubbing away on colour.
Other than that 83k miles, and stood for around 9-12months so I was expecting some gremlins to come to visit.
Drove wonderfully for a week and then warning lights came up. Dreaded TURBO-related issues.
As it's my daily driver I kept using it (steadily) but then about a week ago I long all ignition/power. I found a local guy to help with the investigation and a cloned ECU later it appears that I'm going to be back up and running today.
I'm curious to know what went wrong with it from actual 'Touareg' guys n gals. It flashed up a warning message about the steering lock actuator/sensor, but it wasn't even engaged.
The next bits to sort are the turbos, power wing mirrors and honestly, I want to put lowering links on as I'm not used to being tall yet. Oh, and maybe some R50 wheels.
David
David
